Eastwood Corrolless.....? Painting clean, fresh metal.....mostly!
Discussion in 'The Garage' started by Greg72, Jan 10, 2003.
  1. Greg72
    Mar 5, 2001
    15,682
    1,392
    642 Days to BB2018
    Does anyone know what happened to the product called Corrolless from the Eastwood Company? I can't find it anymore in their listings or catalog, though I now see a product called "Rust Encapsulator"....?
    I have sandblasted a lot of stuff on my truck and 98% of the metal is totally clean. There are some areas where a slight rust pitting exists. I've blasted them as well as I could, but there's probably a slight amount of residual rust in the "pores".....
    Corrolless was an "etching primer" I believe. It was a brick red color, and could be painted over with any paint. I used their Chassis Black paints over it with good results in the past.....but now I'm not sure what product might be best.
    I keep reading about POR-15, but I'm not sure that is the correct product for "clean" metal....it seems that it's main selling point is that you can just brush it over rusty metal and it reacts chemically to stop it. If there is no rust to "react" with, I am left wondering whether it is going to be an effective "first coating" for my restoration work....???
  2. eastk5
    eastk5 Registered Member
    Jul 24, 2001
    50
    Norfolk Virginia
    Yes its the same thing, just a new name. I just used it a bout a month ago when i repainted my blazer. you can now get it in either red or black. great product you wont be disappointed with it.
    Joel
  3. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    greg, they sell a prep for clean metal to etch it,I've bought there starter kit and it has all the thing you need.
    por15
  4. Greg72
    Mar 5, 2001
    15,682
    1,392
    642 Days to BB2018
    Oh yes, the other thing is that I want to "prep" all the metal to keep it from re-rusting, but I will need to probably cut out some metal and weld-in patches.
    I want to make sure that whatever I use is appropriate for this type of followup work. I envision being able to simply "grind off" the paint near the area where I'm working, perform my patches, and then re-spray the protective coating on there..... I don't know if all products are intended for that type of use, or it they are considered a "final coat" once all bodywork is completed????
    I know that for areas where no futher painting will be performed (like inside rocker boxes) they also sell a "cold galvanizing compound" to lock out rust. But it can never be painted over, so it's not always a good solution.
