Easy engine RPM calculator
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by marine_enlisted, Apr 15, 2004.
  1. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    I found this while surfing. I'm sure many of you have seen it, but some may find it very useful...I did. Plug in your tire size, gear ratio, tranny type and MPH, and it tells you your engine RPM. /forums/images/graemlins/thumb.gif
  2. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    You forgot the link...or was this the psychic calculator? /forums/images/graemlins/grin.gif
    Rene
  3. marine_enlisted
    Sep 29, 2002
    658
    Stafford, VA
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    That calculator tells me that with my 33's and 4.10's and 55mph I'm running 2357 rpm's and I know that is WAY off, its more like 2900rpm's
  5. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I agree with muddytazz it is off oh well ...Jason
  6. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    55 mph, 4.10's and 33's with a non lock-up automatic would be 2425 rpm at 55 mph. Time to get a better tach...
    mph x final drive ratio x 355 (for non lock-auto) / tire diameter.
    55 x 4.10 x 355 / 33= 2425 rpm
    with a lock-up tranny or a manual tranny you'd use 336 instead of 355.
    Rene
  7. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    It's right on the money...at least for a manual tranny without OD.
    Rene
  8. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Come down and drive my burb, with the TH350 and fulltime 203 its running HIGH rpm's....you can tell its higher than 2500 rpm's
  9. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    Are you claiming your ear is more accurate than math or a proper tach? /forums/images/graemlins/thinking.gif
    Rene
  10. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I'm not arguing with ya Rene, but with a damn near brand new tach that at 55mph, it definitely sounds like it needs to shift again because of the high sounding rpm's.
  11. marine_enlisted
    Sep 29, 2002
    658
    Stafford, VA
    I'm sure there are gonna be a few variables that this thing won't compensate for. As you know tire hieghts vary greatly due to wheel width, wear, and manufacturers rounding to the nearest larger size. Also, the final drive ratio is not going to be the same for every vehicle.
  12. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    I check my tach using the math, not the other way around. I drove for 4 years with only a tach and no speedo. Using the math I could tell you with 3-4 mph of my true speed. I went through quite a few speed traps without ever getting nailed. In Oregon of all places I've seen the un-manned radar trailers and my speed versus rpm was always very very close to the math. The math works...unless your tranny is slipping badly.
    For true tire diameter measure the circumference and divide by pi.
    At 2500 rpm or so it should sound like it needs to shift again.
    Rene
  13. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
  14. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
  15. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Here is the best one I have ever seen:
    Florida 4x4
    /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif
  16. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Florida 4x4
    If that one I right I normaly going about 80 down the high way. /forums/images/graemlins/yikes.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/whistling.gif
  17. Grim-Reaper
    7,385
    Atlanta
    Looks JUST LIKE randy's that is in the links at the top.
    http://www.ring-pinion.com/calculators/calculatorsind.html
    Wonder who stole from who?
