Easy LED's for gauge cluster
Discussion in 'The Garage' started by dyeager535, Dec 14, 2004.
  1. dyeager535
    26,982
    191
    I'm surprised I hadn't seen this before!
    Perhaps it's been posted, and I've just been ignorant. Checked the supplier mentioned, found the bulbs, only $1.49 each. Really not that bad as long as they put out some good light. Should reduce heat too, which screws up the plastic gauge housing.
    http://s-series.org/modules.php?op=modload&name=Sections&file=index&req=viewarticle&artid=39&page=1
    I should go out on a limb and buy a set of them for the cluster, but I'd sure like to see how they compare to the stock incandescents first.
  2. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    Dim bulbs drive me nuts!!
    Please post back on theese bulbs--every GM truck I have has hardly any bulbs lit bright enough to read the gauges at night--I'm getting tired of using a flashlight to see the dash at night----
    reminds me of the "Rusty Chevrolet" song they play by the DaYoupers this time of year--(sung to the tune of "Jingle Bells")
    "Rust and smoke,the heaters broke,the door just blew away"--
    "I STRIKE A MATCH TO SEE THE DASH--and then I start to pray"--
    "The frame is bent,the muffler went,the radio its ok"--
    "Oh what fun it is to ride in a rusted chevrolet(hay)
    Its a cool song--I dont remeber all the lyrics,but whoever wrote it must have had a few "Rusty Chevrolet's" :)
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    I bought a 98 VW off a friend of mine who is an LED nut. :) He has LED's in place of most bulbs... They wrok good.. not sure if they're really any brighter. But there are some places that offer LEDs with more small bulbs in a bulb....
    There are a few good sites out there that offer LEDs tha are replacements for regular bulbs.... I'll see what I can find.
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I took all of my 194 bulbs out and replaced them with 168. They are easily 2 times as bright.
  6. dyeager535
    26,982
    191
    I've known others to do the same, but after taking apart multiple clusters, I don't think that a higher wattage (heat) bulb is the answer. Some of the "holes" in my plastic housing are already loose, and it is obvious that the problem is caused by heat from just the stock bulbs. The plastic housing warps, and the socket the bulb fits in will no longer stay tight against the housing, so you either end up with inoperative lights, or intermittent lighting.
    I'm not saying it WILL cause problems to use a higher watt bulb, just that it's more likely in the long run.
    LED's could kill three birds with one stone...less heat, more light, longer life.
  7. readymix
    May 30, 2004
    6,706
    26
    I am sure it will cause the cluster to warp and fail eventually........but i will use that as a reason to get aftermarket gauges:thinking::thinking:
  8. vervepipes
    vervepipes Registered Member
    Sep 25, 2004
    20
    Alberta, Canada
    "I'm getting tired of using a flashlight to see the dash at night----"
    thats what i had to do when i first bought my truck: the bulb by the speedo is off more then on, ans the Kph #'s are smaller and darker so they're very hard to see. i now have Mph convertions memorized now though ;)
  9. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    I think it was done by Blue Sparks From Hell. Haven't heard it in years, do you have a copy
  10. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    My gauge cluster in my 79 is nice and bright when all the bulbs are working. I dont have a problem seeing the gauges at all.
  11. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
    the cheap alternative
    the cheap alternative to LEDs in the dash is to paint the reflecting surfaces with chrome bumper paint. its like $5 for a can and it makes a REALLY big difference
  12. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    "The Rusty Chevrolet"
    I have a tape by a group called DaYoupers--they took their name from the place they came from,the upper peninnsula of michigan-they call the folks there "yupers" I guess,,,anyway,I do have the song on tape..if you'd like to year it I'm fairly sure you can find it on Cars.com--go to the "Car Talk" section with Click and Clack,the Tappet Brothers(they have a radio show on NPR you might have heard of)--they have a list of all the songs they have played during the shows--not sure if you can listen to them online though.
    I think more than one group has sung this song--kinda like "Hot Rod Lincoln" a lot of groups covered that song too--..
  13. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    I would definitely like to hear some more about led conversions for blazers or truck. I have had the same problems in the past with the lack of lighting and want to do something about it and not half a$$ it. I am talking about the whole truck though. Headlights, taillights, accents on interior, gauges, dash, glove box, etc etc. Has anyone out there done it and would be willing to do a writeup on it? Or does anyone know where there is some good information about how its done?
    Remington
  14. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
  15. dyeager535
    26,982
    191
    The S10 site I originally linked to has an LED external conversion article as well.
  16. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    can anyone else, not get the s10 site to load? All the traffic from ck5 sank it lol.
  17. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
    What light
    I put some autogauge gauges in the cluster for the engine vitals and you can see thoughs
  18. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    1157 and 1156
    has anyone tried the led replacements for the tail lights
  19. dyeager535
    26,982
    191
    Only ones I have seen in action are ones displayed at local swap meets.
    IMO there aren't enough LED's, and they will end up looking like ricer taillights, with one circle of light, and the rest of the lens dim.
    Perhaps the ones sold by the company in the original link are the "wide angle" type, but I still think that you need a large face of LED's, no matter what, to get away from that pinpoint light effect.
  20. Emmettology 101
    May 9, 2000
    8,126
    FL
    My friend ordered some from that link I added to the thread. They offer a regular and wide beam model.... Wide beams do make a huge difference.
