easy oil pump ? (puttin it on)
Discussion in 'The Garage' started by lazerus, Apr 24, 2003.
  1. lazerus
    lazerus Registered Member
    May 13, 2002
    51
    north texas
    hello all!
    Ok, I think this should be easy. When I dropped the oil pump on the rig, there was a gasket between the pump and the rear cap. (This motor was short blocked at a machine shop.)
    I get a new pump and notice it has no gasket. I ask the parts fellow about a gasket and he says that chevy's do not, nor ever have use a gasket for mounting the pump.
    What gives?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    There isn't supposed to be a gasket there. Check the pump and the rear main cap mating surfaces though for any damage. If there is damage or they don't sit well on eachother, there will be a leak. If this is the case, maybe the shop made a gasket to put in there so it doesn't leak. /forums/images/graemlins/confused.gif
  3. ratlover
    ratlover 1/2 ton status
    Aug 5, 2002
    215
    Peorial IL
    What he said
  4. lazerus
    May 13, 2002
    51
    north texas
    thank ya! I will check it out. /forums/images/graemlins/thumb.gif
