easy stuff.....
Discussion in 'The Garage' started by hi pinion, Oct 5, 2004.
  1. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    what would cause my truck to die?????? i know for one the batt is shot, but i can charge it up enough to get the truck to run for a while ,go down the road.Its like when i press the gas , the truck runs fine, but when i come to a stop, it wants to die. Could a bad batt be causing this??? or does it sound like the alt?? Btw i dont want to risk taking the truck to auto zone,should i take the batt and the alt down there?? have them both ckecked?? Duuu..... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif or just the alt??
  2. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Then buy a new one You cheap fawker /forums/images/graemlins/rolleyes.gif
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  3. hi pinion
    Sep 25, 2003
    5,354
    i thought i could save money by just repeatedly charging it /forums/images/graemlins/dunno.gif /forums/images/graemlins/histerical.gif
  4. hi pinion
    Sep 25, 2003
    5,354
    BTW can you diagnose my problem??? /forums/images/graemlins/rotfl.gif
  5. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    you can ask if they got any used batt. for sale
    sometimes they do down here and there only like15$ abatt i think
  6. hi pinion
    Sep 25, 2003
    5,354
    ill do just that/forums/images/graemlins/thumb.gif but could the batt be causing it to just cut out like that????? /forums/images/graemlins/confused.gif /forums/images/graemlins/thumb.gif
  7. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    it could
    iknow if you take off the power cable while runnin it will die and ive had a bat. so dead it killed my truck everytime i turned on the head lights
  8. hi pinion
    Sep 25, 2003
    5,354
    it could
    [/ QUOTE ] i was told just the opposite, i was told you should be able to remove the cables and the truck should still run /forums/images/graemlins/thinking.gif
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    it could
    Maybe, but you'll fry the alternator in the process, and it'll die shortly thereafter.
  10. hi pinion
    Sep 25, 2003
    5,354
  11. grundy99
    grundy99 1/2 ton status
    Sep 13, 2004
    389
    Loveland, CO
    it could
    You should be able to pull the positive cable off and the engine will keep running. If your alt is bad it will die.
    I have had a problem similar to this his before, if when you come to a stop and keep enough pressure on the gas will it stay running?
    If so you could have a bad fuel filter.
  12. hi pinion
    Sep 25, 2003
    5,354
    thats exactly whats going on, please tell /forums/images/graemlins/thumb.gif
  13. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Why not just check the voltage output at the alt and voltage at the battery??
  14. diesel4me
    Jul 24, 2003
    17,552
    939
    Massachussetts
    I dont know if the battery could cause that,but with EFI maybe they are more sensitive to low voltage than a carbed rig--it might be the fuel has some water in it,around here this time of year the gas stations are switching to the "winter blend"of gas,and I've noticed both some water in my gas I've bought for my mower in the gas can(and I know it wasnt already in there!)and also noticed my rucks have started "pinging"after a fill up there.I put some Shell higher octane gas in one and it stopped pinging,without touching the timing or anything else.My other truck doesnt get used often,so it has a pretty good water build up in the tank--I have to let it warm up for 10 minites before it will pull away without wanting to crap out,and have to hold the gas pedal at fast idle to keep it running at stop signs--adding 4 bottles of isopropanol dry gas made a huge difference in the way it ran--maybe you should do a "piss test" on your gas,and see if its got any water in it,or just toss in a few bottles of dry gas(use only isopropanol in EFI)and see if its any better.. /forums/images/graemlins/thinking.gif
  15. dyeager535
    26,979
    And if it's not bad, this is a very good way to MAKE it bad.
    Check output with a multimeter. Why anyone would test any other way is beyond me. Not having a multimeter is not an excuse.
  16. hi pinion
    Sep 25, 2003
    5,354
    its completely amazing the severe symtoms the blazer through out on just a dead batt........now i put a new one in and it runs killer. /forums/images/graemlins/peace.gif and for those of you who diddnt know,dyeager is the man /forums/images/graemlins/peace.gif its amazing how stumped everyone was on just a DEAD BATTERY!!!! Bwahahaa /forums/images/graemlins/histerical.gif wake up guys /forums/images/graemlins/histerical.gif /forums/images/graemlins/thumb.gif
  17. hi pinion
    Sep 25, 2003
    5,354
    JUST for the record, this little pulling off the battery cables while running fix(wich i diddnt do)was told if you have a computer it can DESTROY the computer completely, among other things,(suprizingly i was told this by the kragen guy lol)......so dont do it!!! YOUL ^%$#$ YOUR TRUCK UP DOING THAT!!! /forums/images/graemlins/thumb.gif
  18. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    It's not EFI, his is an 85 and is still carbed.
    Good to hear it is running again Jake.
  19. hi pinion
    Sep 25, 2003
    5,354
    STFU /forums/images/graemlins/deal.gif /forums/images/graemlins/histerical.gif Yeah its running bitch!!! i got the heavy duty trans too , its only a matter of time before i unleash the picks /forums/images/graemlins/peace.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif BTW these things break down so much, id be better off with a horse and buggy /forums/images/graemlins/thinking.gif /forums/images/graemlins/histerical.gif
