Easy U-joint fix? **PICS**
Discussion in 'The Garage' started by MattG88, Jan 5, 2006.
  1. MattG88
    MattG88 Newbie
    Nov 12, 2005
    MA
    Hey everyone. I own an 88 K5 with a 3" Superlift and 33's. Tonight on my way home from work, my driveshaft decided it wanted to touch the ground. I've never broke/fixed a U-joint before so I was wondering if I could get some opinions if this will be an easy fix. Hopefully I can get some help. Let me know what you think. Thanks
  2. stayaway
    stayaway Registered Member
    Aug 1, 2005
    59
    georgia
    Yep that is a easy fix just a broke ujoint take the c clips out on the driveshaft get ya a socket bigger than the cap size set the shaft on it and bang away from there you should be able to see what is going on
  3. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    Thats not Carnage! thats just a broke U-joint, I always use a soket anda hammer , a vice works too, just press out the old one and press in the new one, even a new guy like yourself should be able to figure it out in under an hour!:D your in the right place for the chevy that ails you!
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    you're gonna have to get a torch for that one. looks to be the stock u joint which GM used a plastic injected in a groove to hold the caps. the new joint will use snap rings which are tons easier to change. I'v used the same socket technic listed above.
  5. MattG88
    MattG88 Newbie
    Nov 12, 2005
    MA
    Thanks for your help guys. Thats all I figured I needed to do. But with me new to the truck world, I just wanted to be 100% sure. What exactly are those caps called so I dont look like a total newbie when I go to AutoZone to get new ones? Just 1U-Joing caps?
  6. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    You buy the whole joint, not just the caps. Buy a manual while you are there, too. Trust me, you'll need it sooner or later. I used to always do the hammer and socket method, but after doing an axle shaft joint or two I became a beliver in using a vise or Very Large c-clamp. Also check your front yoke coming out of the x-fer case for damage.
    Next time change when it starts making that noise (before it breaks)
  7. mikayak390
    mikayak390 Registered Member
    Mar 3, 2005
    70
    NJ
    If your changing one, I'd buy the front and rear joint and replace both. It will save you the trouble in a few weeks. Oh and buy the brute force or anything with a lifetime warrenty. Cheap ones tend to break a year later.
    Oh yea as said above its an easy 20 minute fix. A hammer a punch and a large socket are all you need.
  8. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Also,be careful with the needle bearings,don't want them falling over inside the cap.:D
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    I'd buy new u-joint straps while you're at it too! Looks like it spit out a cap and the joint came out. So your u-joint straps may be worn or out of whack.. Plus they are expensive.
  10. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    U have a grease gun? Gotta lube those U-Joints. Get the best ones u can buy. I buy mine from a local truck parts shop. They cary Dana Spicer joints while auto parts store had crappy Precision brand. I use a press to do my U-Joints. Hammering out U-joints is fine but hammering in can cause some problems if you get over-zealous.
