easy way of identifying 28 vs 30 spline 10bolt front without pulling parts?
Discussion in 'The Garage' started by jjlaughner, Apr 27, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Is there a way to Idenetify them easily? /forums/images/graemlins/ears.gif
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Im sure there is a number cast on the axle somewheres so you can check date of manufacture? I mean they were only used from 88-91 AFAIK.
  3. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    The easiest and only way I know is to pull an axle and count the splines.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    it would be easier to pull the cover and pull the axle spider gears and count the splines.
  5. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Did the number of splines change over the years ? (older vrs. newer)
    I am just curious , wouldn't want to buy parts if they are not a direct swap lol. /forums/images/graemlins/doah.gif
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yes, they changed in 88 I do believe to 30 spline, prior to that they were 28.
  7. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    They changed in 89 AFIK on Blazers.
    (I just double checked the specs page and that is what it says)
