easy way to get frame clean?
Discussion in 'The Garage' started by chevy_tuff, Apr 4, 2004.
  1. chevy_tuff
    chevy_tuff Registered Member
    Apr 4, 2004
    29
    B.C. - Canada
    hey, i just stripped my 80 chev down to the frame and am having a hell of a time getting on the tar and rust off, right now i am grinding and using a wire wheel, any advise on an easier way would b great, ps, i dont have access to a sandblaster. thanks
  2. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    try pressure washing or sandblasting it.
    Nick
  3. unick
    Aug 16, 2003
    4,286
    oh BTW why dont you fill out your profile so we know where you are from.
  4. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    Wire wheel is best bet(no sandblast access). Maybe spray on some degreaser and let it sit and dry. Is the drill/grinder up to the chore?
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    See if you can find a shop with an honest-to-goodness steam cleaner. I had a place do the underside of one of my trucks with one of those many years ago. The results were VERY impressive! /forums/images/graemlins/cool.gif
  6. 78GMC1/2TON4x4
    78GMC1/2TON4x4 1/2 ton status
    Mar 10, 2003
    167
    Mount.Angel, OR
    TRY A STEAM CLEANER. excellent for getting grease off drivetrain and the frame. /forums/images/graemlins/truck.gif
  7. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I would start off with a paint striper(Dads) that should get you down to all metal, then if you cant sand blast it get a angle grinder and a couple of good wire wheels, you may need a more corse wheel to start with then what your using now but rember not to dig to deep into the metal by using a corse wheel and letting it sit in 1place to long
    Also you might wanna try one of those sanding disks they put on grinders ive never used one but might be a good idea...
  8. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    You can rent sand blasters. I've seen great results when they are used. Of course you probably need to rent an ultra-high output air compressor too... But once you're done, you don't need to do it again...
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    oven cleaner and scraper and goggles and pressure washer
  10. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    What does the oven cleaner do /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif
  11. rnss82
    rnss82 Registered Member
    Mar 28, 2004
    22
    oregon,wa.
    i have found that a 4.5'' grinder works great for that stuff thats what i had to do. the only thang is that you have to use a wire wheel and alot of time and beer lol
    /forums/images/graemlins/rotfl.gif
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It removes grease from your frame the same way it does from an oven. Works great!!
  13. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I'll Have to do that, it is okay to use on greasy driveline components too?
  14. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    I used the corner edge of wire cups on my angle grinder. I went pretty fast.
