Easy way to lift a t-case and tranny combo
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Leadfoot, Oct 16, 2001.
  1. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    http://coloradok5.com/gallery/Leadfoot
  2. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    How about a cherry picker thru the passenger door with a chain fed down thru the transfer case shifter hole. That way, you have nothing below the trans/transfer to get in your way, especially a floor jack! I've used this method for 20 years and have yet to find an easier way to install a tranny/transfer assembly.
    ken
  3. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    I used two 15000 lbs ratchet strapps hooked to the frame on each side . one under the transmission and the other under the t-case like a sling and ratcheted the assembly in place with cross member still bolted on so i just had to put the bolts in the frame.
    A BIG HAMMER CAN FIX ANYTHING.... [​IMG]
  4. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    I pulled the hard top off, punched a whole through the windshield, ran a chain through the whole and around the top of the cab, and ran a come-along thru the t-case hole in the floor. Of course this was on a part's truck. That is when I learned that a sm465 and 205 t-case assembly is very heavy. Had to roll it on to a spare hood and hook a tow strap to it and pulled it with a truck to get it to the garage. I love my new cherrypicker!!!!
    Keep it simple <a target="_blank" href=http://coloradok5.com/gallery/album71>http://coloradok5.com/gallery/album71</a>
  5. Tatman
    Tatman Registered Member
    Oct 2, 2001
    80
    Indiana
    Hey Ken... where are your chain mounting points when going thru the shifter hole? Been looking for an easier way than the floor jack.
    Brian
    <a target="_blank" href=http://www.saddletramps.com/BlazerK5.htm>www.saddletramps.com/BlazerK5.htm</a>
  6. Leadfoot
    Nov 28, 2000
    3,112
    This way I don't have to take any of the interior apart (well ok, I did have to remove the shift knob). I left the boot, carpet, etc. all intact. Once the engine was in the mounts (I rebuilt the motor too) and had the tranny/t-case mounted on the jack. It took me all of maybe 5 minutes to get them mated to the engine dowel pins and all the bellhousing bolts started and torqued down. It took me a few more minutes to get a jack stand to hold the t-case up when I removed the hybrid tranny jack, so I could bolt the crossmember in place. I have used the cherry picker through the shifter hole method before, but it CAN be awkward. Plus it takes too much time with one person. If it is not at the right height, you have to get out and lift/lower the picker, try to manuever it, tilt it etc. With the modified tranny jack, you can lift, tilt, and manuever it all with one hand without having to physically move. I've done it with a regular floor jack too with ratchet straps, and also have done it by muscling the tranny in first and then the t-case in by hand on another vehicle and between all the methods this was the quickest, cleanest, and easiest install. I am in the process of building a similar apparatus for my floor jack (I hate having to alway borrow tools) because it IS that much easier (Definitely worth the time it takes to build and scrap metal is cheap).
    As far as anything being in the way, the jack is only under there just long enough to get the assembly bolted to the motor. Then there is a jack/jackstand in the way for another 10 minutes while you bolt the crossmember in place and then you can remove it and nothing is in the way. Plus it's skinny enough that it isn't in the way when trying to start/tighten the bellhousing bolts.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot>http://coloradok5.com/gallery/Leadfoot</a>
