Easy way to tell a dodge 60 from a chev?
Discussion in 'The Garage' started by 8_YOUR_H2, Oct 9, 2002.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I have decided to get a 60 from a 4X4 boneyard close to me. I dont want to say the guy is shady but I will say I want to have my ducks in a row before I go out there. Is there an easy way, with out whipping out the tape measure, to tell if a 60 is from a dodge or chev? Can anyone tell me if all chev 60's came with 35 spline inner shafts.
    I would HATE to go out there and get some odd ball 17 spline, ball joint, 5.5" ring gear D60 that came in the 1963 chevy ice cream truck or some crap like that.
    Thanks homies...
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    dodge uses a different stearing arm oh and dodges have there brake lines come down to the pumpkin area and then into a t and atatche(sp?) to the tubes and run to each calliper. other than that i think you would need to use a tape /forums/images/graemlins/smile.gif
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Sorry, best bet is to measure the perches.
    -- Mike
  4. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    The Dodge D60 will have a steering arm that is basically straight (pointed towards the spring like a Chevy) with a slight rise to it where as a Chevy has a downward slope and a bend towards the rear.
    The shock mounts on the Dodge axles I've seen are simple flat steel tabs with a stud for the shock to mount on.
    As previously stated, a Dodge will have a " T " bolted to the long side axle tube with a hard brake line running to each wheel and then a short rubber line to the caliper.
  5. NetBlazer
    NetBlazer Registered Member
    Apr 23, 2001
    90
    Littleton, CO
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif You're killin' me!
