"Easygrind mig wire" a godsend
Discussion in 'The Body Shop' started by camiswelding, May 11, 2004.
  1. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    \"Easygrind mig wire\" a godsend
    Ive heard about it from my street rod buds for a long time and gave it a try... "easygrind" in .025.... its is awesome autobody wire... nice and soft for sheetmetal.. minimal burn through even at higher amperage...025 is good max for about 12 ga,,,
    I give it an A plus.... try it and you wont be disappointed
    Wish I had it when I did the rockers!
    cam
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Re: \"Easygrind mig wire\" a godsend
    As a welder I appreciate the tip, thanks! /forums/images/graemlins/waytogo.gif
  3. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    As a hopeful future welder I appreciate it as well. /forums/images/graemlins/peace.gif
  4. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Where do you buy this stuff?
  5. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    We all wanna know? /forums/images/graemlins/whistling.gif
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Its a special rare breed of wire. Breed from the finest lineage of wire. Avaliable only from selected breeders! /forums/images/graemlins/rotfl.gif
  7. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    I got mine at sierra airgas here in kalifornia... Im not sure who the manufacturer is.... all the bodyshops apparently use this stuff//// a good supplier should know about it right away
    cam.... aka mr sparky
  8. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Hmmm, I take it this is not flux-core huh?
    General question: any special flux-core wire you would use for body-repair? I've got just the standard .030" Lincoln flux core...I figure low heat setting, small tack welds, and my grinder/wire brush should make everything look okay? No? /forums/images/graemlins/thinking.gif
  9. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    A few years ago, one of the mags did an article about body work and they mentioned this wire. Don't remember the specifics, but if ya searched Lincoln's website, I bet it could be found.
  10. namkrow
    namkrow 1/2 ton status
    Apr 25, 2004
    166
    So Cal
    I bought some .023 non-flux core mig wire the other day.
    Radner brand? (can't remember)
    Got it at airgas.
    Had to get new drive rollers for my Miller and tips.
    really easy to weld sheetmetal now!
    .030 was ok, but this stuff works a LOT better.
    -T
  11. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    tom is right... smaller diameter wires are easier to use from the get go as they require less input amperage to weld well... what makes easygrind mig wire nice is its metal composition... its softer on the rockewell scale and "easier to grind"....with a body hammer handy you can tap down tack welds making the whole job smoother... I find when I was using 030 before... even the best stuff that I would get burn through fairly easily with my sp 250 lincoln/300 powermig... not so with the easygrind stuff.... also has lots of oxidizers in it because they know youre probably going to be welding on previously galvied matal...
    By using lots of tacks and playing connect them from opposite ends to keep the heat down to the panel you can do pretty thin metal with good penetration... 18 ga fairly easily... after that i pull out the tig...
    Easygrind is not flux core...I use 75/25 argon/co2 gold gas
    I only use flux core for outdoor pipe welding and fabbing... takes to much clean up when I need a appearance weld... great for pipeline work out of my LN-7 but I have to run 052 and thats no good for "pretty" work
  12. flatline
    flatline 1/2 ton status
    Sep 9, 2004
    167
    Cincinnati, Ohio (area)
  13. Evolrider
    Evolrider Registered Member
    Jul 17, 2010
    22
    Bay Area Ca.
    Esab makes an Easygrind wire, nonflux, in .023, Airgas in my area has it, but they only had the 11lb spools.
