eaton axles
Discussion in 'The Garage' started by tree_entz, May 12, 2004.
  1. tree_entz
    tree_entz 1/2 ton status
    May 4, 2004
    141
    N. Vermont
    i've run into some older 70's chevys and have seen the old eaton axles. Just wondering what you all know about them. /forums/images/graemlins/ears.gif
    I really dont want anything that old just for it being a PITA getting parts and stuff. just curious. /forums/images/graemlins/thinking.gif
  2. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    they have drop out thirds like a Ford 9 inch and also have a diff cover. pretty strong, but the axleshafts only have 17 splines. there are a few people out there who have swapped 14b internals into these and made them alot stronger.
    i'm going to slap a stock eaton h052 under my gmc, the axle came factory with a detroit locker and was dirt cheap.
    i have heard it is hard to find new drums for these axles, but there is a disc brake kit available.
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Yep, the 14FF axle shafts, detroit locker and disc brake kit will fit the Eatons /forums/images/graemlins/thumb.gif
  4. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    I just bought a whole eaton rear, open 4.10's for $75. now I gotta figure out where to buy a ring & pinion set for it, and how to get my welding stick down into the carrier to freeze up the spiders
  5. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Kenny, can you or anyone else get the measurement from axle center to low spot under the diff.? I want to compare to a 14BFF.
    Thanks in adavance. /forums/images/graemlins/thumb.gif
  6. kennyw
    Jun 9, 2002
    13,223
    94
    I should be able to after this weekend when I pickup my axle housing from storage, pumpkin is sitting at home though with the axle shafts from a 14FF...
  7. thedrip
    Dec 13, 2003
    1,129
    Chattanooga, TN
    I went out and checked, looks to be right about 6.5"
  8. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    Will my 14FF Gov loc Drop right into the eaton axle if I swap over the axle shafts and R&P, or is it only the detroits that work?
  9. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    Thanks! /forums/images/graemlins/thumb.gif
    Kenny, looks like I have the info. Thanks anyway!
  10. kennyw
    Jun 9, 2002
    13,223
    94
    I dont think it will work because the carrier is different. You have to keep the Eaton Carrier to put the 14FF detroit into it.
