Eaton E-locker
Discussion in 'The Garage' started by Mastiff, Jan 19, 2006.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Does anyone have one of these? What's the concensus? I really like the idea of a selectable locker for my front D60 since I drive around on winter roads sometimes. Sounds like maybe the Electrac isn't the best? Plus I don't like that it's still posi when off, which might be squirrelly on-road in the front in winter.
    Is it conceivable that a novice mechanic could install something like this? I'm kind of scared about having to setup the gears and all that. How tough is it? Or maybe I should just find a shop nearby to do it for me (if/when I go for it)?
    Finally, would my 86 CUCV D60 front be 35 spline? I know it's 4.56. Thanks.
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,993
    130
    Yes its 35 spline. The E-locker is good (better than an ARB, IMO) but good luck finding one. Eaton has been real slow on getting these out. You can try, and if you can find one go for it. As far as setting up the gears again, all you will have to reset is backlash, which isn't too bad (and in my experience with detroits I didn't need to change a thing). Just post up here when you are ready and we'll help ya out.
  3. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
  4. gm500hprat
    gm500hprat 1/2 ton status
    Feb 28, 2005
    196
    anaheim, ca
    They may sell them but i doubt I have them in stock. I work at Currie Enterprises and Extreme4x4.com my boss has 2 of the original 3 or 4 pairs built that did not go in the H2. And he only has them because the Curries wanted to test them out and he had 2 rigs in the shop being built. But when he tried to get some on his own they are just not sittin anywhere long enough to be found. I think the production of the H2's are using up most of the e-lockers.
