Eaton HO72 Yoke Needed. 14bolt swap?
Discussion in 'The Garage' started by OrangeCrushK10, Jan 18, 2005.
  1. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    I need a new Eaton HO72 (rear 3/4ton or 1ton axles, 72&older) pinion yoke since mine's all busted up. Does somebody have one or does anybody know if I can swap a 14-bolt's yoke into it without changing anything else?
    Thanks!
  2. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    the 14 bolt's will not work. Jess at High angle driveline had a 1410 yoke custom made for a guy with an Eaton on the pbb, and I dont think it was too expensive.
