Eaton hubs
Discussion in 'Parts & Trucks Wanted' started by 1967k10, Nov 25, 2005.
  1. 1967k10
    1967k10 1/2 ton status
    Nov 21, 2005
    1,728
    Nebraska looking for D60's
    I need a set of Eaton hubs with the 9/16" studs off a 71' or 72'.Need to be in good shape.
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    I'm not possitive on this, but you might try comparing them to a 14FF... I think they may be the same. Many parts of the Eaton and 14FF are interchangeable.
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    14b studs are 9/16th.
  4. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
    i have heard this also. like the shafts and lockers will swap to a eaton axle. my friend just did a disk kit on one with a 14ff kit no problems.
  5. 1967k10
    Nov 21, 2005
    1,728
    The 14bolt ones won't work without matchining.Yes the 14bolt studs will work but I can't find the right size of drill bit to drill out my hubs.The 14bolt shafts,disc kits,Detroit's,and 1 set or bearings interchange.
  6. 4bynut
    4bynut 1/2 ton status
    Sep 21, 2004
    675
    Morrison, IL
    I have several eaton HO72 rears here. I might part with a set of hubs depending on what they are worth. Let me know what you would spend for a pair and i might sell a pair. Thank's Jason
  7. 1967k10
    Nov 21, 2005
    1,728
    Anyone else have a set or am I going to have to go junkyard huntin'?
