eaton info
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 69K5, Oct 18, 2003.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    looking for info on the eaton rear ends. eo72 specifically. nayone know a sit on these? just general questions
    what size are the u bolts? can i flip them where they point up?
    what are the little 1/2 blocks for under the spring pack?
    thanks
    69k5
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I think the block under the spring pack is just the mounting plate for the u-bolts.
    Measure the axle tube across to find it's diameter, that will give you the u-bolt size.
    Yes they can be flipped to point up, you will need to get or fab new plates for the top of the springs.
    Be prepared to weld up the tubes, as the lower mount holds salt and crap which corrodes the axle tube. You will want a solid level mounting surface for the u-bolts to rest on....
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i dont think it is. its on the bottom of the spring pack and on top of the perch like a zerorate would be. i will try to get a pic up.
    thanks for the help
    69k5
  4. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    I had the same block it's about an inch tall. Came on the 3/4 ton trucks. Have a pic in the link in my sig.
  5. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    cool thanks thats it
