Eaton Posi. Does anyone know if it will work on my blaze!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GRINCH, May 18, 2002.
  1. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    EATON 8.5 30 SPLINE LOCKER/POSI FROM A 1999 CHEVROLET TRUCK.
    I have a 1990 K5 with the factory 10 bolts. I added 4.11 gears and my limited slip went out and have a chance on getting this eaton. Will it work and what's it worth?
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I have an eaton posi in my 10 bolt rear. However, mine is a 8.5" 28 spine, for 3.73.
    Be sure to get the same gear #, its not like a bolt on locker.
  3. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    I belive in 88 or 89 they went to 30spline 10bolts... it should work but don't take my word for it.
  4. dyeager535
    26,979
    Yu should be able to check with a reputable shop to se if part #'s are the same for the carrier. I do know that the housing changed somewhere around that vintage, perhaps to denote the change to disks or something, but the housing is not exactly like "ours", and there could have been other internal changes as well.
  5. 91K5
    91K5 1/2 ton status
    Jul 5, 2000
    185
    Wichita, Kansas
    You need to make sure that the donor posi is a 4 series if you want to retain your gears. The "series" denotes the numerical gears it runs, a 3 series for 3.08 to 3.73 gears, 4 series for 4.11 to 4.56, etc.
  6. GRINCH
    Jan 30, 2001
    1,951
    Helena, MT
    Not doubting your info, But I have been searching for some time and looking on eatons and other websites and only see the same part # for all 30 Spline units. They say for an 8 1/2 it's #... for 2.76 and up. The 8 7/8 units (never heard of them)vary by ratio.
    Thanks for you input. Here's some info I found.
    Check it out at <a target="_blank" href=http:///www.motivegear.com/eaton/differential_assemblies.html>/www.motivegear.com/eaton/differential_assemblies.html</a>
  7. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    8 7/8'' = 8.875'' = GM12bolt
