eaton rear axel question
Discussion in 'The Garage' started by 69K5, Jul 13, 2005.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    long story short. finally moving to the new house. while i was towing the blazer rear passenger side hub bearings went out. the hub is shot and the bearings or whats left are obviously gone. turned it around put the front wheels on the ground to finish the trip.
    how do i check the housing to see if its ok. I didnt see any cracks in it. i'm having a hard time getting the hub off. the wheel did move back and fourth about 2 inches. drove no more than 2 miles after an initial stop and inspection before i noticed the wheel flopping in the mirror.
    I dont want to replace the hubs and bearings if the housing could be messed up.
    on the subject anyone have some hubs close to louisiana?
    thanks
    69k5
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I'd take a vernier caliper and measure both spindles on the housing. If they don't match for size.... pretty good sign its toast.
    To check for straightness... set up the bare housing on axle stands. Spin it around and have a buddy watch carefully from each end. If its bent you can see it wobble.
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    thanks. now wish me luck i just got the locker put in.
