eaton rear brake / 14ff parts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by daimok, May 30, 2003.
  1. daimok
    daimok Registered Member
    Jul 18, 2002
    40
    north carolina
    ok , about to get my 83 k5 going with the monster 1969 one ton rear axle. man the drums on this thing are HUGE , 3 inch brake pads , 7 inches from the back of the drum to the start of the wheels studs. anyways when i pulled the drums ( 50 pounds each ) i found the brakes are missing the emergency brake lever and transfer bar. does some one with a 14 bolt one ton axle have any of the parts loose to take some measurements ?
    new wheel cylinders were $60 each /forums/images/graemlins/eek.gif
    thanks in advance
    daimok
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Would probably be cheaper to go disc than to fix the drum brakes.
    -- Mike
  3. daimok
    Jul 18, 2002
    40
    north carolina
    i would love to find someone that sells a rear disc conversion for this old strange axle , anyone know of a place ?
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you can use parts from a 3/4 ton dana 44 axle, 1/2 ton 44 front calipers work
  5. daimok
    Jul 18, 2002
    40
    north carolina
    if i use front calipers , i loose emergency brakes dont i ? they look for that during inspections , lucky i know someone in low places and can get one (inspection ) no questions asked
  6. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    use Eldorado calipers, i want to say 1978, but im not sure, somone on here will know though. If you searched you would find out which year too.
  7. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    [/ QUOTE ] Mico Lock. Press brakes, throw the lever and walk away. Same thing Wreckers use. Parking brake. /forums/images/graemlins/thumb.gif
