Eaton rear-disks
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by ntaj*ep, Sep 16, 2002.
  1. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    OK, the time has come to actually do something with the 3/4,1ton rear-end I bought. Its an Eaton and I want to know who is running this and do you have disks on it? Oh and I assume that to run 15" wheels with the disks would be the same as if it were in the front,as far as grinding? or.........
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Not to many folks use/modify the Eaton rear only because parts are not as avaliable as the 14/60/12 rears. For example try and get a R&P set in a 4.56. You may beable to find one but from what I hear most R&P makers just don't make parts for the Eatons /forums/images/icons/frown.gif
    No first hand experiance just what I have read so I could be wrong /forums/images/icons/crazy.gif
    Good Luck
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
  4. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Randys ring and pinion came out with gear sets from 3.90 to 5.13 a while back.
  5. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    I have the hook-up on everything R&P related. /forums/images/icons/grin.gif I do quite a few set-ups. /forums/images/icons/grin.gif So not a problem.
  6. Burt4x4
    6,854
    Sweet!! Good luck on the disks!!
    Late
  7. cornfed
    cornfed 1/2 ton status
    Oct 15, 2001
    295
    washougal wa
    Hey where are you at in Washington? pretty sure everythings the same as converting a 14 bolt. If you have the hookup on gears do you have any 5.13s around? I need to replace a spare set. EATONS RULE!!!!!!!
  8. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    Hay thanks Beast388! They have lots of cool stuff. There in my state too!!! /forums/images/icons/grin.gif WooHoo!
    I think the 14bff is the same. But I'm giong to check it out. /forums/images/icons/tongue.gif
    I don't have any "good" 5.13s for the Eaton, but I can get some. /forums/images/icons/wink.gif
  9. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    No prob.....anytime! /forums/images/icons/grin.gif
  10. cornfed
    Oct 15, 2001
    295
    washougal wa
    hey ntajeep i need two sets when can you get em and how much?
