Eaton rear disks?
Discussion in 'The Garage' started by ntaj*ep, Sep 17, 2002.
  1. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    OK, the time has come to actually do something with the 3/4,1ton rear-end I bought. Its an Eaton and I want to know who is running this and do you have disks on it? Oh and I assume that to run 15" wheels with the disks would be the same as if it were in the front,as far as grinding? or.........
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    If this Eaton is the big 12" ring gear rear end, you are in luck as the rear disc brackets for the 14FF will fit the Eaton rears no problem. /forums/images/icons/wink.gif
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    What would you use for the rotors? Same as the 14 Bolt? Just made my old axle look a little more interesting... All the drums were shot from brake hardware rolling around in the bottom anyway but the hubs and bearings are still good.
  4. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    ok Aarom, PM Don in spokane he is huge eaton fan and has a few /forums/images/icons/wink.gif he might even be a parts hook up. Don is also his user name /forums/images/icons/wink.gif I bet some Quad Raptor 2,000 spoke Daytons would fit that eaton /forums/images/icons/grin.gif
