eaton rear end
Discussion in 'The Garage' started by 69K5, Jan 3, 2003.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    does anyone have a pic of an eaton rear end out of a 72 chevy? figured out this is what is under the truck im getting form the first gen board. i thought it looked kinda like a 9 inch but it was stuck to low in the mud to get a good see. the owner said the truck was all original.
    also where can you find parts and how do you look up axel seals, bearings ect??? under chevrolet or eaton?? parts store is dumb as usual? anyone know where a schematic is on the web?
    one last question anyone seen a kit for rear disc? i did a search on google and came uop with nada on all of the above questions
    thanks a mil!
    nathan
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    watch out, some one will try to sell you a "racing" ford 9" for "weight" reasons /forums/images/graemlins/rolleyes.gif
  3. BARRAZA
    BARRAZA 1/2 ton status
    Oct 17, 2001
    259
    USA
    Yeah, an Eaton looks kind of like a big 9inch. Came in 3/4 72 trucks. I have read that gear selection is kind of limited, but you shouldn't have a problem with bearings and seals etc. if you go to a real parts store, not autozone. Otherwise a rear shop like Randys should could surely provide most any part. And a 14ff from a later model 1 ton is a bolt in almost, just move shock mounts. Far as I know, your on your own for the discs.
  4. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    For the rear discs try www.tsmmfg.com they look a little expensive but its a start. Maybe someone here can even make them if you can get them the specs.
  5. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    the eaton is just under the donor truck and i will definatley not put a ford 9 inch in there when you drive this beast weight doesnt really matter anymore. whats it gonna do hurt the gas mileage? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif. if i could come up with 125.00 i would just by the 14ff.
    i am gonna check the tsm page listed above for brakes.
    thanks for all the help.
    nathan /forums/images/graemlins/k5.gif
  6. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    according to tsm the disc brakes from a 14ff will fit an eaton from 64 - 72. i will just go with derbinator b/c hes cheaper.
    thanks
    nathan
  7. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    An eaton in a 72 would have a removable rear cover that is round. I would pull it and check the gear ratio. Also a lot of them came from the factory with a detroit locker that has since been disconninued so finding a used one is the only option for those axles.
    I take it the donor truck is 4x4? Otherwise it would be a coil spring suspension.
  8. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    the Eaton 14FF book of knowledge is ck5 member "Don" in Spokane, pm him he is the eaton god /forums/images/graemlins/thumb.gif
  9. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Here's a pic:
    There is a chance it may have a factory (or dealer installed) Detroit No-spin (yes, locker) /forums/images/graemlins/thumb.gif
    Possible ratios are 4.10, 4.57, 4.88, and 5.12. Only ever pulled a 4.10 or 4.57 from a 3/4-ton.
    Brake swapping on these old things is great. The hub is essentially matched to the housing, but you can use 13" drums and backing plates froma 14FF, or as already mentioned, the 14FF disc kits.
  10. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    I can't wait to do this swap on mine!!
    The pictures have me all bothered now...........whew!! /forums/images/graemlins/eek.gif
  11. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    kenny w
    the donor truck is a 4wd. i was originally just going to get it for the front axel. then the guy said only the whole thing or no deal.
    uglu chevy
    thjanks i'll be dropping him a line.
    u2slow
    thanks for the pics thats exactly what it is. how do itell the gear count the teeth and divide?? there was no plate on it that said?
    ntaj*ep
    i'll let you know how mine goes
    thanks
    again to everyone.
    nathan
    69K5
