Eaton
Discussion in 'The Garage' started by pumpkin, Feb 16, 2006.
  1. pumpkin
    pumpkin Registered Member
    Nov 5, 2004
    14
    Just read the article on 14 bolt shaving, so I went out and measured the pumpkin clearance on my blzer on 35's. I have 11.25" of clearance, and a heavyer duty rear end than a 14 bolt. I'm running an eaton with 4.56 detroit locker. G.M. used this rear diff up untill about 1972 in trucks from 3/4t to 5t. Living in Canada these diffs are getting harder to find, but down in the states, they're just junk in old trucks. Find some and send them to me:D
  2. chevyguybc
    chevyguybc 1/2 ton status
    Nov 12, 2003
    524
    Vancouver Canada
    pumpkin you lucky dog. ill be shaving my 14 bolt quite a bit..
  3. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    are parts gears and lockers as available for the eatons though?
    balzer
  4. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    You can buy bearings, brake parts (drum or disc), and even gears NEW for the Eaton axles. I know that some of the stuff gets pricy, and I don't think you can buy new 5.13's, but if you need it you can get it.
    Tractech (Eaton) no longer makes the No-Spin for it...junkyard, eBay, or convert to 14 bolt axleshafts and then use 14 bolt whatever.
  5. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    sorry to say that pumpkins truck was rear ended! shes being written off and hes going to rebuild another early blazer!:mad::mad::mad::mad::(:(:(:doah:
