echobit and brake?
Discussion in 'The Garage' started by Bhintz, Dec 16, 2003.
  1. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    trying to change rear drum pads on my k5 and never have done it w/ the 14 bolt ff in the back do I have to take the axle out to get to the pads and to get the shoe off??? and if thats the case will the shoe come right off or is there a bolt or something??? and Im putting on a echobit shackle flip when Im done w/ the brakes and is the nut that comes w/ the kit suppose to have a plastic stop thing in the end of the nut so you cant tighten it anymore?? /forums/images/graemlins/1zhelp.gif
  2. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    For the rear brakes you'll have to pull the shafts and take out the nut holding the hub on. Pull the hub and drum off as an assembly. Change pads as you would on any drum brake vehicle. Better yet, switch to disks! /forums/images/graemlins/thinking.gif
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Be ready to drop your drums. A drum and hub assembly feel like about 45+ lbs.
    Is that nut you are talking about a nyloc nut?
  4. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Yeah, he is talking about the nylock nut. And to answer his question, there is supposed to be plastic inside.
    -Harrison
  5. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    alright thanks /forums/images/graemlins/thumb.gif
