Echobit flip, how much lift?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sled_dog, Feb 19, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    How much does the echobit flip kit really give in peoples experience? I looking for 6" of lift nad have about 1.5 out back already from some nice stiff 3/4 ton+ capacity springs.
  2. Langosta39
    Langosta39 1/2 ton status
    Nov 8, 2002
    156
    Moscow, Idaho
    Sounds like your in luck. I put the echobit flip on my truck and got about 4 1/2 or 5 inches so it'll work just fine. Great kit, well built, good price, the hardest part is getting the old hardware off but you have to watch your pinion angle. You might have to move your spring perches or shim quite a bit.
    andy
  3. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I think he can set you up with longer shackles if needed...
  4. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    how many degree shim you think I would need? i mean what angle? I guess I could move my spring perches, I am sure of my welding skills but not of my ability to put them in the right spots for the right angle.
  6. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    They will give you 5.25" of rear lift, reusing your stock shackles.
    How much the pinion needs to be shimmed is variable. I have a longbed pickup with a non-CV shaft and I needed 8 degrees. A blazer might not need any.
    -- Mike
