Echobit Flip Kit? Yay/nay? ORD flip?
Discussion in 'The Garage' started by BowtieRed, Jun 12, 2003.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Who has either? Worth the money? How's installation?
    thanks,
    red
  2. jekbrown
    May 19, 2001
    45,032
    366
    Vancouver, WA, USA
    i have a 4" ord shack flip. Its top quality, just like everything else ORD makes. Installation isnt too bad, especially if u have a grinder or air chisel or something to get the factory spring hanger bracket rivets out. If you dont have a grinder and are gonna drill the rivets out... dont, go rent a grinder! makes the install soooooooo easy.
    from what i have heard the echobit flip is even easier to install... but I have never seen one first hand so I'll let some1 else speak to them....
    j
  3. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Love ORD, But have a Echobit Flip! Install in under 20 Minutes!!!!(Had Axles off) Echobit all the way, top notch! I've been working on moving hangeers to install 63" springs, rivits are a Bastard! I Drilled all mine out and it wasn't too bad, just start with new bits and all! A ASharp bit makes all the difference! I couldn't get the grinder into some of the spots I wanted it! /forums/images/graemlins/thumb.gif
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Springer Suspension System
    goobs of flex. i use a 16" stroke shock and use every bit of it.
    Marv interupted his BBQ at his place to answer a few questions. Great guy, great suspension! /forums/images/graemlins/thumb.gif
    install was a breeze, did it in an afternoon
  5. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    no good, i'd have to get 8" lift springs from an F150
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    you think 11.5" springs are gonna flex? /forums/images/graemlins/rotfl.gif
  7. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    You mean like this:
    There are ways of making you flex!
  8. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Echobit...
  9. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    no- they are 8" springs
  10. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    gokarter are those your factory shackles? im considering an echobit kit myself but am trying to understand it better.
  11. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
  12. 85burbanator
    Feb 10, 2003
    577
    lake orion, mi
    yea you gave me that link once and i saved it but i just wanted to get a visual to see what i might be doing. and now i know. thank you much /forums/images/graemlins/thumb.gif
    oh yea, how much lift did you gain from the shackle lift
  13. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Im looking at doing a shackle flip also but echobit is definetly cheaper than ORD, but ORD looks much cleaner. 5.5" is alot too, did it hurt your pinion angle? I have 6" springs now. Do you have any complaints about the ehcobit?
  14. bigblock44k5
    Jun 8, 2003
    396
    Hurlburt Field, FL
    zakk, I visited the site you gave but they dont give any info at all. How much was it? By the looks of the picture they have it looks like you need longer spring is this true? thanks
  15. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    Echobit Flip Kit! more lift, can remove from the truck and go back to stock
  16. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
  17. Batmanjr
    Mar 23, 2001
    1,537
    The amou8nt of lift is about 5-6" de3pending on how settled your rear springs are! I had 4" springs up front and had to add adaleafs in the front to really level them out! It's extreamly easy to bolt on, the fact that you're lowering the rear of the spring compensates for the driveshaft angle and you use your stock shackles! YOU DON"T NEED NEW SPRINGS! These are made to be mounted with the stock springs! /forums/images/graemlins/thumb.gif
  18. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    yup, 57" ford springs that flex like mad.
    8" leafs with a 4" shackle flip won't flex very well, the Ford springs in stock form will net you about 4-5" of lift. they can get you up to 7" or so without hurting flex too much...
  19. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    You mean like this:
    that does not look like 8" springs....
  20. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Yes, I put in 6 degree shims.. Soon as I get a chance I will reweld the perchs.. But the shims are fine right know...
