echobit flip
Discussion in 'The Garage' started by outlawtorn, Sep 16, 2004.
  1. outlawtorn
    outlawtorn 1/2 ton status
    Jul 21, 2004
    365
    Box Elder, SD
    Did they discontinue or what because i cant seem to find them?? /forums/images/graemlins/confused.gif
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    gone for almost a year now. He snaked out owing people money and parts /forums/images/graemlins/angryfire.gif
  3. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Too bad too. They were pretty good.
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I think the ORD shackle flip is better designed.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It's also more than twice the price.
  6. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
  7. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    I wouldn't say better designed but a different way to do it. Alot of people don't want to grind the crap out of rivets to pull the hanger and pull the tank (not neccesary) but safer just to add 4"s of lift with good flex. I used echobits measurements and built bolt on flips out of 3/8ths steel plate, the design doesn't allow mine to move like his did neccesitating welding them to the hanger so they didn't move. I am in the process of redesigning them to be more shapely and cutting edge look wise. Check my sig for the first design.
  8. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
  9. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    PM magnum4x4 . He is the one I mentioned earlier that makes them
  10. outlawtorn
    Jul 21, 2004
    365
    Box Elder, SD
    those sky mountain's dont look to bad might have to give em a call /forums/images/graemlins/thumb.gif
  11. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Just go get you some 2wd front spring hanger mount from a junkyard, tons cheaper and you can put them where ever you want /forums/images/graemlins/thumb.gif
  12. NerdBoy
    NerdBoy 1/2 ton status
    Dec 24, 2002
    429
    Southern Illinois
    I used echobits measurements and built bolt on flips out of 3/8ths steel plate, the design doesn't allow mine to move like his did neccesitating welding them to the hanger so they didn't move. ... Check my sig for the first design.
    I can vouch for that. I have a set of backyardbuilt's flips. Never had a problem with them. Gave me the lift I wanted, and are extremely stout.
  13. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Why do you need 2wd hangers? I used 4x hangers and they work fine, only problem is they don't line the springs up quite as well with the front hanger (rear hanger is too close to frame) /forums/images/graemlins/dunno.gif
  14. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    4x4 hangers are alot bigger and give you more lift than most people are looking for. The front 2 wheel drive ones are 1/2 the size of the 4x4 version. If you want a bigger lift you can use them though, as you know they still work.
  15. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    I cut mine down to size and they work just fine. /forums/images/graemlins/thumb.gif
  16. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    That works too!!
  17. outlawtorn
    Jul 21, 2004
    365
    Box Elder, SD
    so just any front spring hangers off of a 2wheel chevy?
  18. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Any front , rear axle hangers yes.
