Echobit Shackel Flip a little too snug?
Discussion in 'The Garage' started by TXsizeK5, Jan 21, 2003.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Well I have my EZ rides upfront and Echobit flips in the rear. Its alot softer upfrton but out back it seems harder... would the shackle flip being a little too snug do this by preventing articulation?
    Thanks,
    dC
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    IIRC, he gives torque specs of 60ftlbs. /forums/images/graemlins/thumb.gif
    -Dan
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    The bolt that holds the flip bracket to the stock bracket must be snug - you don't want it loosening for any reason.
    The bolt that holds the shackle to the bracket should be a little loose for flex, whether you have a flip or not.
    -- Mike
  4. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    sounds like your rear springs are too stiff.
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I agree on checking the bolts. I think spec from GM is like 52 foot pounds or so. Seems that some people like to crank on them.
  6. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    "The bolt that holds the flip bracket to the stock bracket must be snug - you don't want it loosening for any reason.
    The bolt that holds the shackle to the bracket should be a little loose for flex, whether you have a flip or not."
    What do you mean? You just said the same thing twice and contradicted yourself... or maybe i just odnt understand.
  7. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I think he meant that the spring to the bottom of Echobits bolt should be the looser one.
  8. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    The upper bolt that holds the echobit flip bracket to the stock spring hanger(on the frame), should be tight. The lower bolt on the echobit flip bracket should be loose to allow the shackle to move.
  9. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I am talking about three seperate parts.
    1. The stock brakcet. It is riveted to the frame.
    2. The flip bracket. You buy this from echobit.
    3. The shackle. The originally bolts to the stock bracket on one side and the spring eye on the other. After the flip, it will bolt to the flip bracket on one side and the spring eye on the other.
    Sorry if I'm making it sounds complicated, but really it's not.
    -- Mike
  10. landsmasher
    landsmasher 1/2 ton status
    Mar 13, 2002
    4,423
    California, The Blow Me State
    Why don't you ask the guy that runs the place you bought them from?
  11. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I just found this thread. Two things to look for:
    1. Check your shackle brackets and make sure they are installed so the shackle mounting hole is placed 1" forward, and not 1" back. Having them 1" back will make the suspension feel stiffer with stock springs.
    2. The shackle flip bracket should be torqued down to 60 ft lbs to the stock shackle hanger but the bolt used to mount the shackle in the shackle flip bracket should not be real tight.
    Getting the shackle bolts tight enough that they don't come loose, and loose enough so as not to restrict shackle movement can be a balancing act sometimes. I only use nylock nuts on all my suspension components, especially the shackles.This way I can barely seat them and leave them loose without risk of them vibrating off.
    Were the stock shackles a tight fit to mount into the shackle flip bracket?
    Its hard to tell if you use a hi-lift to do one side at a time, which places a little twist on the leaf assembly durring installation and makes things install tight.
    Let me know what you find Derek. I'm always looking to improve on these brackets, perhaps you've run into something others haven't.
    - Mike
