echobit style flip question
Discussion in 'The Garage' started by sandawgk5, Aug 24, 2005.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Are there any design issues with the echobit style of shackle flip? I dont see many people running them is it just because they dont make them anymore are is there something fundamentally wrong with the design.
    Ira
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I'd say it is because they are no longer made(seems to be an obvious reason why people aren't getting them). Plenty of people run them, and did buy them, when they were sold.
  3. ksblaze83
    ksblaze83 1/2 ton status
    Sep 11, 2004
    329
    Topeka, KS
    not possitive if he's still selling them, but backyardbuilt sold me a set about a year ago.
  4. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    The design was fine...
    The only complaints I'd heard were about the build quality (fit issues mostly) and then of course the whole fiasco where the company took a bunch of money for orders and then closed up shop and disappeared....
    I actually bought a new-in-box Echobit flip kit a while back. My intention was to duplicate the original kit (maybe making a few improvements) and then start offering it for sale again. I feel that the market is still strong for the product, especially from a source with the integrity to fill orders in a timely manner and deliver a quality product....
    :thinking:
    Hmmmmm......maybe I should build a couple dozen and start pimping them as a "Vendor" around here to test my theory?
  5. ZooMad75
    ZooMad75 1/2 ton status Premium Member GMOTM Winner
    Apr 5, 2003
    998
    583
    Pueblo, CO
    I've got the echobit flip on mine. Got it used with no instructions. qualitywise mine were very well built, nice welds. My problem was since it had been used the process of torquing the bolt that holds it to the stock hanger caused the ends to pinch in. This made for a tight fit over my hangers. Only thing we could use to open it up was a hydraulic porta-power. But once we did the flip brackets slid right on.
    Way easier than drilling/removing the rivits and installing brackets in the stock location.
  6. sandawgk5
    Oct 28, 2003
    6,881
    Are you stuck with running 52s with this setup or will the shackle accomadate for the extra 4" of spring on a 56. The echobit style flip is by far more simple than drilling rivits but I want to run 56's for obvious reasons :D
    Ira
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    The echobit flip was designed to bolt to your existing spring hanger.
  8. sandawgk5
    Oct 28, 2003
    6,881
    I know I was just wondering if you could only run 52s with it or can I run 56s.
    Ira
  9. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    does anyone have pics?
  10. sandawgk5
    Oct 28, 2003
    6,881
    There is a set in the for sale section with pics.
    here
    Ira
  11. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    Nope.. I finished mine yesterday I'll post pics all you'd have to do is swap what bracket goes on what side..hope that makes sense..But i am now running 52" springs :D
  12. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
  13. sandawgk5
    Oct 28, 2003
    6,881
    If I gotta remove rivets anyway I will just go with the ORD or DIY flip to allow me to run 56s.
    Thanks for the info.
    Ira
  14. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    I didn't remove any rivets :confused:
  15. sandawgk5
    Oct 28, 2003
    6,881
    I understand that to run 52s there is no need to remove rivets. However I intend to run 56s which requires the spring hangers to be moved rearward=>I would have to remove the rivets inorder to move the spring hanger.
    Ira
  16. ZooMad75
    Apr 5, 2003
    998
    583
    Pueblo, CO
    Somebody might chime in here, but I thought I remember seeing on the ecobit website that you could run 56" springs if you swap the brackets side to side.... If you look at the holes, the new hole for the shackle is not directly in line with the upper hole where the bracket bolts to the stock spring hanger.
    Do some searching and I think you might find an old thread on the guy from echobit using 56" springs.
  17. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    You can run a 56" with the echobit. No rivets to move, but I would suggest a longer shackel for a bit better angle. You can see the longer belltech shackel in my pictures :D
  18. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    EDIT!
    pics above are 56" springs :D
  19. sandawgk5
    Oct 28, 2003
    6,881
    oohhhhhhh. I thought you had 52s MY BAD :D :D
    I misunderstood I thought you meant you had to swap the spring hangers side to side not the echobit brackets.
    Ira
  20. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I have the Echobit flip in my K5, and I have beat the SH!T out of that thing for over 3 years w/o any problems at all. I run mine w/ the sides switched and a longer shackle w/ Ford 57's and it works perfect... and stretches the wheelbase out around 6" or so.
