ECM 1 is cold... ECM B is hot
Discussion in 'The Garage' started by camiswelding, Apr 30, 2004.
  1. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    tracing computer goblins in my v 3500 tbi bb crew...
    No fast idle and hard start after I put in a dual battery system with optimas... (although the installation/problems may have been coincidental)
    Anyway after install truck was hard to start... no fast idle, no check engine light when in the on position...
    Put a reader on and no codes were there... noticed my radio clock had reset itslf each time I shut truck down
    Checked fusebox and found NO POWER to ecm 1 fuse and hot always at ecm b fuse.... does anyone know if ECM1 fuse is supposed to be hot all the time?
    I suspect my computer is not getting power like its supposed to..
    This is basically a new truck with 39k miles on it and is pretty much mint otherwise....
    cam
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Have you checked your fuseable links at the starter?
  3. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    will look at those kenny thanks for the tip....
    cam
