ECM B fuse blowing
Discussion in 'The Garage' started by yeager1, Jan 15, 2005.
  1. yeager1
    yeager1 Registered Member
    Jan 15, 2005
    5
    US
    I keep blowing my ECM-b fuse in my 87 K-30 (350 TBI) and I am not sure why. I know that the fuel pump is on that fuse but I don't think the pump is the problem, but the wiring could be. What else is on that fuse? I have a manual, but it's not a factory one and the wiring diagrams are not very good. Any thoughts as to what wires/components are on the ECM B fuse? Does anybody know where I can download a good wiring diagram?
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I had that problem when I had a fuel pump lockup, thats all I can tell you.
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    This has been covered a lot recently. It would be worth doing a search.
  4. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    try unplugging the connector to the fuel pump and then turning the key to run with it unconnected. itll be on the inside of the drivers side frame rail near the tank. if the fuse doesnt blow, try replacing the fuel pump relay, like 8$. the relay should be on the passenger side of the firewall at the top. also, look for any pinched and/or bare wires going to the fuel pump, relay, injectors, etc.
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    What gets power through the B fuse?
  6. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    check all your sensor wires especially the cps ( cranshaft position sensor). I blew my ecm b fuse when i did a swap... i was extending the wires to fit the 355 and touched the two bare cps wires that i was extending together, they sparked and it blew. If you have exposed wires anywhere on that circuit the fuse can blow.
  7. yeager1
    Jan 15, 2005
    5
    US
    Thanks for the info! I'll give it a try and get back to you.
  8. yeager1
    Jan 15, 2005
    5
    US
    I checked the wiring to the fuel pump and it looked marginal, so I replaced the wiring all the way from the tank to the fuse block (there was no relay- goes directly from tank to fuse panel. The pump works and runs fine, but the ECM B fuse still blows- I guess the fuel pump is on a different fuse.
    Anyway- The ecm b (10a) fuse still blows and the truck won't start- I disconnected all the wiring to the coil and distributor and the fuse still blew. Tommorrow I am going to pull all the wiring out of the harness and check wire by wire for any shorts. Any other suggestions? Without a decent wiring diagram I am kind of at a loss.
  9. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    Might be a good idea to pick up a manual with the vacuum/wiring diagrams. I can't think of any other reason that fuse would blow besides a bad circuit meaning shouted wires somewhere on the fuse circuit. I am positive the pump is on the ecm b fuse. All i can tell you .... good luck
  10. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    Try un plugging the ECM and seeing if it still blows.... If it doesnt, bad computer, if it still does, bad wiring. I hooked my battery up wrong and fried my ecm and it was doing the same things as you are saying.
    Hope this Helps.ROB
  11. yeager1
    Jan 15, 2005
    5
    US
    The ECM was bad- replaced it and it started right up. :grin: Thanks for the info.
