ECM code 43
Discussion in 'The Garage' started by MTBLAZER89, Jun 9, 2003.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Anybody ever gotten this? Electronic spark timing is what my manual says. It says replace Knock sensor and/or ESC module. I was just wondering if anybody else has had any luck with any simple fixes.
    -Brian
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    I have the same Code that I get all the freakin time, Ive replaced the knock sensor twice and the ESC once. Also tried advancing the timing and nothing has helped. /forums/images/graemlins/angryfire.gif
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    i used to get this, havent seen it in a while though, i think setting the timing to stock got rid of it, my timing got off after all these years i guess.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    btw, my code 43 was always accompanied by pinging, again, making me think it was a timing issue
  5. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Mine does this, too. No one I've taken it to can figure it out. My code 43 is accompanied by nothing, it doesn't even change how it runs. Bizarre...
  6. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Hmmm when my check engine light comes on it doesn't run very good kinda misses. Also when I idle or drive my sometimes my tach bounces about 250 RPM's. I figure something is wrong with my spark somewhere. Any suggestions?? /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif
    -Brian
  7. zcarczar
    Feb 10, 2002
    2,495
    Check the usual suspects, plug wires, cap, rotor, ignition module and coil.
