ECM... GM or Reman?
Discussion in 'The Garage' started by Hossbaby50, Dec 15, 2003.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am about to go get another ECM for my TPI swap. I am having problems with a no pulse from the injectors and my next test is to try a new ECM and see if that solves my problem. I also need a spare anyway. (01227165)
    I was wondering if a reman. unit from Checker is ok? Or should I try and find a used GM unit? Checker units are $90 which I find to be a pretty good price. What should I use? Thanks
    Harley
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    The GM units shouldnt be anymore than the one from Checkers. AC Delco actually remanfactures them to keep the cost low, I know a few months ago we got one at work for an 89 R-30 and the PCM was only $90 or so.
  3. dyeager535
    26,975
    I'd get a used GM one that was "known good".
    Might be able to put you in touch with someone that might have access to one, or you might check www.thirdgen.org classifieds.
