ECMB fuse blown? Truck just dies like ignition dead?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by performance1, Aug 5, 2002.
  1. performance1
    performance1 Registered Member
    Jul 9, 2001
    Los Angeles. CA
    This info might save someone hours of headache that I recently went through:
    About 6 months ago I was on the freeway going about 70mph downhill when my ignition just died. Pulled over and figured out that I had popped the 10amp ECMB fuse. Replaced it, and went about my trip with no problems. Just last week, I had the same thing happen again, but became a real pain when I started popping these fuses (With resulting engine stalling) at the rate of one fuse every 2-40 miles.
    Must be a common problem, because dealer was quick to deduce that issue was with defective fuel sending unit, located in gas tank. Expensive fix ($284 part at Napa, plus $50 more for new fuel pump, all AC Delco), but everything works great now!
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    Undisclosed Location
    A few years ago, I had an ignition module go out, blew the fuse. Injector went out, blew the fuse, then after all was fixed, all was well.
