ECU location?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Piranha300, Jan 10, 2004.
  1. Piranha300
    Piranha300 Registered Member
    Jul 1, 2001
    45
    Nebraska
    Before I tear into my 91k5 looking for it I was wondering if someone could tell me where it is? Also the parts store here has 3 to choose from... how can I identify mine? Thanks
  2. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    Should be behind the glove box and a little bit up.
    You can match it by the serial number on the tag which is on the ECU.
  3. Piranha300
    Jul 1, 2001
    45
    Nebraska
  4. skratch
    Oct 28, 2003
    1,646
    Gorveport, OH
    No problem, always ready to help a fellow Cornhusker out! /forums/images/graemlins/thumb.gif[​IMG]
    I hope that helps.
  5. dyeager535
    26,975
    Just make sure it's the ECM before you go and buy one. They do go bad, but ratio of times ECM's are replaced vs. actual fixes from that is pretty low.
  6. Piranha300
    Jul 1, 2001
    45
    Nebraska
    Yea I hope its my fix. When it gets real cold the tranny wont shift until I reset the computer. When warmed up things are fine. My TPS sensor is new. It went bad at the same time as my brake sensor.
  7. dyeager535
    26,975
    So do you get a code 12 when you test the ECM? There are ways to diagnose this short of replacing the whole thing.
  8. BayouBlazer88
    BayouBlazer88 1/2 ton status
    Jul 31, 2002
    353
    Lafayette, LA
    Just curious, is the part your replacing the entire metal computer box or just one of the chips? And if its the entire unit you're replacing, how much did the ones you saw cost and what store?
