Edelbrock 1406 - Brackets and Cables
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by johnny reb, Aug 2, 2005.
  1. johnny reb
    johnny reb 1/2 ton status
    Mar 6, 2000
    326
    Pittsburgh, PA
    I just got a Edelbrock 1406 to install in my 86K5. It will be installed on top of an Edelbrock 3701 Performer Intake. I have a 700r4 tranny.
    According to Lokar I need the following hardware to make this carb work with my setup...
    Throttle Cable - TC1000HT
    Kick Down Cable - KD2700HT
    Bracket - SRK4000
    EGR Adapter - EDL1476
    These all appear to be stainless steel cables and brackets and I don't want to spend $100+ dollars for all of this if I don't need it.
    Can I get away with using all of the stock cables and simply purchasing this TCI corrector kit instead (TCI-376710)?
  2. XCUATRO
    XCUATRO Registered Member
    Jul 4, 2002
    31
    so. cal.
    I just did that same setup as yours but on a 1976. Ended up using Edelbrock bracket #8036 for the tranny kickdown and throttle cable. Check out www.edelbrock.com under installation items. Hope this helps. :crazy:
  3. trailblazer86
    trailblazer86 1/2 ton status
    May 16, 2004
    112
    North Shore of Lake Ontario
    After all the money that I spent on my Adptabrock, and now someone makes a kit?
    The EGR adapter is nessarry, the Cables and brackets will surely make the insatllation much easier.
    I am now running the old Quadrajet to make sure the TV cable adjustments are correct. These parts look good to me and I will also be spending the money for the brackets and cables
    Thank you for letting me know.
