Edelbrock 1406- can't get full throttle
Discussion in 'The Garage' started by odoa3, Sep 15, 2004.
  1. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    Edelbrock 1406- can\'t get full throttle
    When I put my foot into the throttle I can't get full throttle. I think it is something to do with how the cable is run. It runs through a bracket that bolts on the carb. However, the bracket does not fit on both carb studs. Does anyone have a 1406- if so how did you mount the throttle cable? Pictures would be great if you have them.
  2. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Re: Edelbrock 1406- can\'t get full throttle
    I have a bracket that goes on the two back studs. The cable attaches to the front of the linkage. I can get some pictures before I go to work on Wednesday.
  3. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    I had to get an adjustable bracket to get mine to open all the way. Without adjusting the bracket back toward the firewall about half and inch the cable was to loose and the first inch throttle cable travel was lost.
  4. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    My cable is pretty loose as well. I bet that is the issue. /forums/images/graemlins/thinking.gif Where did you get an adjustable bracket?
  5. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    The stock brackets work the best. Go to the junk yard and get one.
    -Chris
  6. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    I have the stock bracket right now, I believe. Only one bolt will match up with Edelbrock carb.
