Edelbrock 1406 carb on spread bore intake?
Discussion in 'The Garage' started by odoa3, Sep 17, 2006.
  1. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    Wondering if anyone has put an Edelbrock 1406 on a spread bore intake without an adapter, just using the standard four hole gasket? The previous owner of my K5 had the Edelbrock carb on using an adapter, but the adaptar covers half of the primaries :eek1:! I am thinking that this could be causing some of my power loss issue.
    Thanks guys.
  2. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    you mean like tapping the current intake?
  3. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    it only works if you have an edelbrock intake. They are drilled and tapped to acomadate bot styles and will seal fine using either style carb.
  4. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    I have Weind dual plain, spread bore intake., I was hoping to put a Quadrajet on it, but the the three we tried this weekend, didn't work. My buddy thinks we are not getting a good seal. So I was hoping to use the Edelbrock without the completely incorrect adapter that was on it. Guess I will have to spend some money on the correct adapter.
  5. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    I have a 1406 on my stock spreadbore manifold, I did use an adapter though,sounds like the wrong adapter to me.
