Edelbrock 1406 elec choke question
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by HarryL, Apr 2, 2001.
  1. HarryL
    HarryL 1/2 ton status
    Feb 25, 2001
    139
    Layton, UT (20 miles north of SLC)
    from where do I run a live wire to the electric choke? This edelbrock seems to run goofy without the electric choke hooked up.
    Harry
  2. blazin72
    blazin72 1/2 ton status
    Oct 24, 2000
    279
    Oklahoma
    I ran mine to the fuse box to where it has power when the switch is on. Look for the same power wire that the radio is going to on the fuse box and that one should work.
    Blazin 72
  3. HarryL
    Feb 25, 2001
    139
    Well, I don't have a radio hooked up yet, but it should be easy enough to find "radio" marked on the fuse box, eh?
    Thanks for your help.
    Harry
  4. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Don't use the radio power. It switches on with the accessory positino as well as with the ignition. Make a splitter wire and use the IGN terminal on the fuse box.
  5. HarryL
    Feb 25, 2001
    139
    Hola Steve,
    Please explain a little more precisely what you mean by "make a splitter wire". It probably makes sense if I think about it :-), but I was wondering if you would just 'splain me.
    Harry
  6. blazin72
    Oct 24, 2000
    279
    Oklahoma
    Yea
    Let me clear that up the radio wire would work but like he said it would be on in accessory mode as well.
    I dont know if that would hurt but probably wouldnt be right.
    I was just trying to give you a idea on how it wires up.
    Just splice into the ignition wire on the fuse box.
    Blazin 72
  7. Steve_Chin
    Mar 6, 2001
    1,126
    Harry, what I call a "splitter wire" is one that splits the single terminal on a given electrical circuit into two. In this case, it'd have a female connector that would connect to the single male lead marked IGN on the fuse box. There'd be two reasonably sized wires coming out of this female connector (14 AWG), and each would end in a male connector. The original ignition lead would connect to one of the male connectors, and the new choke lead would connect to the other male connector. Basically, it "splits" the power...
  8. HarryL
    Feb 25, 2001
    139
    Steve,
    Thanks for your precise reply. I could see it in my mind as I read it. I'm going to go out and try that in a little bit.
    Now if I could only get my foreign language lesson plans that clear!
    Harry
