Edelbrock 1406
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Todd 91, Oct 16, 2002.
  1. Todd 91
    Todd 91 Registered Member
    Aug 15, 2002
    30
    Middle Missouri
    Put an Edelbrock 1406 carb and 2101 intake on the 85 Chev, 305 engine. Now, when I start it up, it immediately goes to around 2200 rpm. After about a minute to a minute and a half, I hit the gas and it idles down to 600-700rpm. I know this is right for it to step down but isn't 2200 high? Can I adjust that anyway? Choke? It's really bothering me the way it sits up there and screams.
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yes it is adjustable but I can't help you with how with the Edelbrock. /forums/images/graemlins/confused.gif
    You should check on the sides of the carb, you should see a stepped plate with a screw that goes on it's edge, and holds the throttle open.
    I know on the Q jet but not on this one sorry
  3. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    the 1406 has an electric choke, i think you just have to loosen the screws holding the choke cap on and turn it one way or the other, experement with the engine running
