Edelbrock 1910 - Installed
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Mar 8, 2002.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    All right... I got it installed... and took a test drive. Sad to say, that I am really disappointed with the lack of power vs. the Holley. HOWEVER, after playing in the snow a little bit, I can say this for the 1910... I CAN'T MAKE IT STALL! I can climb anything, and the carb just keeps right on running just as smooth as it was on the street!
    Granted I have not done ANY tuning on the carb yet, I slapped it on and drove off basically. /forums/images/icons/blush.gif I had glanced thru the manual and noticed that there are a lot of tuning tips there that may need to be done to make this thing work in tip-top shape. Any good suggestions from peeps who already have the 1910, as to what to do first to make this poor QJet happy? I need my top end power back!
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Tuning the secondaries is where you'll make the top end gains back. Spend some time reading the book that came with the carb first though. I doubt you'll ever match the Holley's top end, but it should come reasonably close with some tweaking.
    Rene
  3. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Cool somebody other than a magazine to test it out. What kind of angles did you test at? Did you try to drive up a wall to see if it would stall before your flipping point? The 1910 will most likey replace the edelbrock I have now.
  4. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    I did drive up a wall.. matter of fact, I nearly set the truck on the rear bumper! /forums/images/icons/blush.gif I go tthe front tires about 7-8 feet off the ground.The truck didn't choke, stumble, or bog at all at a extreme upward angle, or on slanted surfaces. I have tried everything but a "nose down" test. LIke I said, the stability of this carb makes up for its lack of top end power. I am satisfide with the way the carb operated "out of the box", but I am sure that with some tweaking, the carb will be top notch.
    Hope this helps!
    -Dan
  5. 4GUNZ4X4Z
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Cool thats what I wanna hear let me know when you do a nose test.
