edelbrock 1910
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by ChadL, Oct 6, 2002.
  1. ChadL
    ChadL Registered Member
    Mar 31, 2001
    13
    I've been gone a long while; sure is good to be back!!! J ust ordered an Edelbrock 1910 q-jet replacement carb w/elec. choke. Any one done this and know the amperage of the fuse I need to put inline? Anything else I should be aware of?
  2. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I have a 1910 on my 79 with a 355 (my Qjet died and I'm building a big block so I thought it would be a good match). I ran switched ignition power from the fuse block to the carb's choke with a 20amp fuse, but that same fuse also sends power to my blower motor relay. Anything from 10 to 15 should be fine. Start with the lower amp rating and if it blows, go to the next higher.
  3. Robin
    Robin 1/2 ton status
    Oct 30, 2001
    184
    Georgetown, Texas
    Good thought... I need to do that!
