Edelbrock carb and 700r4 cable hookup.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BrightBlazer, Sep 20, 2002.
  1. BrightBlazer
    BrightBlazer Registered Member
    Dec 17, 2001
    11
    MICHIGAN
    Early this spring I swapped an Edelbrock carb and intake onto the stock 305 in my 86. I cant remember how I hooked up the cable to the carb but do remember I had to "rig" something.
    Is there a "good" way to do this?
    What did you guys do?
  2. mudober
    mudober Registered Member
    Feb 19, 2002
    23
    I used the factory bracket.
  3. BrightBlazer
    Dec 17, 2001
    11
    MICHIGAN
    OK I finally got back into the truck to get it going for the winter. I used the stock bracket that holds the cable. Bolted it to the intake-Holley street dominator. The actuall connection of the cable to the carb is with a home made bracket that bolts to the carb linkage and connected it to a screw in the bracket. Basically I would have had to stretch the cable too far and there was no stud to hook the cable too. If I remember right I could not get the stud out of the stock carb.
