Edelbrock Carb Question
Discussion in 'The Garage' started by 2High4U, Aug 28, 2005.
  1. 2High4U
    2High4U 1/2 ton status
    Aug 20, 2005
    542
    Felton Pennsylvania
    Im having a problem with my carb it keeps sticking I need to know what the factory adjustment is for the screw below the idle screw on the linkage its not the two on the front or the idle screw its the other one :doah:
    I think i figured out why its cutting out now the electric fuel pump is connected through the mechanical one so im gonna disconnect it and hook it directly to the carb hope that works ;)
  2. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    I only know of 2 external adjustments on a Edelbog.......idle speed and idle air/fuel mixture, are you referring to the fast-idle solenoid if so equipped :confused:
  3. 2High4U
    Aug 20, 2005
    542
    Felton Pennsylvania
    Carb Screw Location
    The screw I am referring to is below the linkage you have to hold it open full throttle to be able to adjust it and see it. I think that it has something to do with the movement of the butterflies on the front of the carb. It doesnt have a selenoid anywhere that I am aware of. this carb has in front the 2 mixture screws and on the linkage it has the idle screw but below that if you open the throttle all of the way you will see the other screw that I am talking about
  4. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    u have 1406? if not what one u have
