edelbrock carb
Discussion in 'The Garage' started by mundosk5, Jan 21, 2007.
  1. mundosk5
    mundosk5 Registered Member
    May 31, 2006
    9
    booty booty land
    hey just got a edelbrock carb and on my current setup i have 350 chevy with a q jet carb and new fuel pump (mech) and 2 new filters (one inline i installed !!my question is will i have enough fuel pressure with the stock mech fuel pump to simply bolt on my new carb??? or do i have to go buy a new fuel pump and filters???
  2. WantedaDodge
    WantedaDodge 1/2 ton status
    Dec 16, 2004
    282
    Eugene, OR
    Should have plenty of fuel pressure unless your pump is worn out.
    I'm not a big fan of edelbrocks, so I never ran them much, but I've been told they shouldn't get much more then like 6 PSI fuel pressure or they'll leak. I don't know if that's true or not, maybe someone can confirm.
  3. 90v1500
    90v1500 Registered Member
    Oct 1, 2004
    56
    Huntsville, AL
    I run several Edelbrock carbs and ideal on any carb is about 6 lbs. but a stock mechanical pump can put out 8 - 10 lbs. and I don't have any problems at that pressure...:D
  4. mundosk5
    May 31, 2006
    9
    booty booty land
    so u have ran with the stock mech fuel pump with no problems???
  5. fordeater
    fordeater 1/2 ton status Premium Member
    Mar 21, 2004
    1,402
    Missoula, Montana
    I've got an edelbrock on my 350 with stock mechanical fuel pump. It runs fine with no problems at all.
  6. TC70C10
    TC70C10 Registered Member
    Aug 15, 2002
    26
    harvest, AL
    Same here. I run two fuel filters. No problems.. Their manual says 4-5psi. If yours is still starving for gas it says you can switch to their larger needle and seat #1466.
    I might try swapping the needle and seat to their off-road setup #1465. I use my truck to 4 wheel quite a bit during hunting season
  7. 90v1500
    Oct 1, 2004
    56
    Huntsville, AL
    Yeah, stock pumps no problems... Sometimes you can have to much pressure, you need to check your fuel pressure. If it gets to high it can push pass the float and flood the engine with to much fuel...:rolleyes:
  8. mundosk5
    May 31, 2006
    9
    booty booty land
    :wink1: i can start wrenching asp to get that carb on!!!!
