Edelbrock Carbs!
Discussion in 'The Garage' started by skink4president, Nov 29, 2005.
  1. skink4president
    skink4president Registered Member
    Mar 5, 2005
    79
    orlando
    Just put a new Edelbrock Performer #1400 w/electric choke on my K5 350/350. Had an older edelbrock w/ manual choke on it before. Now I've got a low end bog. Timing is good (10 BTDC). I think it may be related to the electric choke although the problem still seems to happen when warmed up and the choke is fully open at operating temp.
    Any ideas??? (other than, "take it off and put on a Holley!") :D
  2. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Is bolting the new carb to the engine the only thing you have done? Are the carburater idle mixture screws adjusted properly?
  3. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Check vacuum advance, vacuum leaks, idle adj and main jetting.
  4. BROKEN-ONE
    BROKEN-ONE Registered Member
    Sep 15, 2005
    78
    kansas
    try this
    there is a second hole adjustment on the acclerator pump try it after you check the other posts. hope this helps .
  5. skink4president
    Mar 5, 2005
    79
    orlando
    Yeah. I just bolted it up to the new intake. According to Edelbrock they come "pre-adjusted" for either economy or performance. I' ve fooled with the choke to some extent but that's about it. Honestly, this is my first square-bore. I've made adjustments on Q-jets and Holleys before but never one of these. Hell, I haven't even figured out how to adjust the idle yet! :crazy:
  6. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    you could have got a electric choke kit for yours cheeper.
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    :doah: you sir are in BIG trouble if you cant figure out how to adjust idle on an AFB, but have messed with Holleys and QJets.
  8. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Use a vacuum gauge and adjust the idle mixture. :waytogo:
    Also Edelbrock carbs are crap for wheeling. I talk from experience. Cant climb a molehill without sputtering and dieing. Then a bee-atch to restart. Im running a Barry Grant Speed Demon now. Why? Because its what I had. I got the thing to stall on a bumpy 2 track. Then trying to stop and steer with the motor dead was fun. Get a Q-Jet. Or at least a Holly truck avenger.
  9. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I've had good luck offroading my edlebrock, but I used their offroad needle kit and adjusted per instructions. I also run an electric fuel pump. I have stalled, but only on the steepest of hills. I will be installing a TBI system in the next couple of months, to fix the slight stalling I had.
  10. sweetk30
    Nov 1, 2004
    25,537
    536
    yep same for me.
