edelbrock multi point efi
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by therover87, Jun 25, 2001.
  1. therover87
    therover87 1/2 ton status
    Jun 24, 2001
    139
    Long Island, New York
    i have a 1987 k5 and i was wondering if the edelbrock multi point efi kit is first worth the money and am i gonna see good results. my other question is that should i just go and buy a crate engine or go with the edelbrock multi point efi kit.
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Well if your looking for low end torque(1K-3K), I don't think the edelbrock, is what your looking for.
    If you current set up is not putting out 260 lbs./ft. then maybe a new motor is inorder.
    Good luck
  3. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    "Worth the money" means many things to many people. It all depends on what you're looking to get out of your engine. I had all the power I needed out of my stock engine with an Edelbrock 600 on it. I'm going to TBI right now for the added reliability / driveability. A crate motor would probably be a better use of your money if you've got a marginal engine already. Then you could always go for EFI at a later date. In the end, it all boils down to what your preference is.
  4. therover87
    Jun 24, 2001
    139
    well if i go with the crate engine then i have to get the wiring of all the computer equipment for the throttle body but if i go with the edlebrock set up is all bolt on, when i say worth the money i am not talking about the price am i going to see good results
  5. KENT
    KENT 1/2 ton status
    139
    Roseburg, OR
    I though that GM made create motors that included all of the EFI stuff. Was I dreaming?
    Kent
    1989 K5
  6. YaleChevyMan
    YaleChevyMan Registered Member
    Jun 24, 2001
    5
  7. Executioner
    Feb 22, 2000
    1,530
    IMHO you will not see good results !
  8. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I like my Edelbrock MPFI on my 468. EASY to tune in, controls spark and fuel, uses common sensors, bolts on easy, etc. I like that there is no laptop involved.
    Bang for the buck? get a little more displacement and a fresh motor with the $2200 and put your factory system on it with a larger throttlebody and a new chip. This should make a 383 pretty happy.
    If you're looking for something that you can tune to the hilt, and adapt to different motors and different parts in a motor, I think the Edlebrock MPFI is the way.
    Making the world better, one truck at a time.
    [image]http://coloradok5.com/logo_ordsmall.gif[/image]
    SW-ORD
