edelbrock multi point efi
Discussion in 'The Garage' started by 89Burben, Oct 3, 2006.
  1. 89Burben
    89Burben Registered Member
    Jan 3, 2005
    98
    CT
    Just was wondering if anyone has done this on a BBC. its the kit that converts tbi trucks to speed density multipoint injection. How much better is it really than the old tbi setup?
    The only reason i am asking is becuase i upgraded to a little better flowing heads making more compression and a very mild comp cam. The truck seems to run good, but at higher rpms (4,000-5,000) it sometimes backfires through the Throttle body. I am thinking it is lean at higher rpms...
    i also have a chip currently
  2. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Wally, the ORD K5, has an Edelbrock mpfi kit on a 505 bbc. It's supposed to make good power.
  3. dyeager535
    26,975
    If you didn't monkey with the PROM after changing heads, you need to.
    Either have someone look at it while it's running, or datalog and provide to someone who will, or learn to do it all yourself.
    Very likely you are running lean, and/or too much or too little timing, all of which can damage the engine.
  4. 89Burben
    Jan 3, 2005
    98
    CT
    i havea chip that was burnt from brian at tbi chips. however it was not made specifically for my cam/head combo. I had him make me one a few years back when i just put in the big block, and i didnt notice much performance, so i took it out since my engine was stock. After i put on the 1966 427 closed chamber heads, and the comp cam i put the chip back in since the truck was backfiring when accellerating hard.
    I then talked to brian at tbi chips and he looked at my data logging and said to set the timing at 8* advanced (it was at 0*). Since then its ran much better but it seems to run lean at higher rpms like i said. (4000-5000)
    It has only backfired once through the tbi after i changed the timing to 8*. It was when i was doing a burnout and the tranny shifted from 2nd to 1st and the tach when up to 4000rpms and it poped through the tbi once and then i let off.....kinda sounded like a fire cracker
    can anyone here read the win aldl to help me out?
  5. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,921
    331
    Fort McMurray, Alberta
    sure, post it up and I'll take a look :)
  6. 89Burben
    Jan 3, 2005
    98
    CT
    BLM
    Narrow Latest
    RPM \ MAP 20 30 40 50 60 70 80 90 100
    400 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
    800 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
    1200 0.0 120.0 0.0 0.0 0.0 0.0 133.0 0.0 0.0
    1600 0.0 119.0 125.0 0.0 118.0 0.0 0.0 0.0 0.0
    2000 0.0 0.0 0.0 0.0 119.0 132.0 133.0 0.0 0.0
    2400 0.0 0.0 0.0 0.0 0.0 0.0 128.0 0.0 0.0
    2800 0.0 0.0 121.0 127.0 0.0 0.0 0.0 135.0 0.0
    3200 0.0 0.0 0.0 0.0 0.0 0.0 0.0 139.0 0.0
    3600 0.0 0.0 122.0 0.0 0.0 0.0 0.0 0.0 0.0
    4000 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
    4400 0.0 0.0 0.0 0.0 0.0 0.0 0.0 140.0 0.0
    4800 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
    5200 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
    5600 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
    6000 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
    6400 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
    Narrow Avg
    1200 0.0 120.5 0.0 0.0 0.0 0.0 133.0 0.0 0.0
    1600 0.0 119.7 119.1 0.0 123.0 0.0 0.0 0.0 0.0
    2000 0.0 0.0 0.0 0.0 124.0 132.0 133.0 0.0 0.0
    Narrow # Sapmles
    400 0 0 0 0 0 0 0 0 0
    800 0 0 0 0 0 0 0 0 0
    1200 0 2 0 0 0 0 1 0 0
    1600 0 3 7 0 2 0 0 0 0
    2000 0 0 0 0 4 1 1 0 0
    2400 0 0 0 0 0 0 1 0 0
    2800 0 0 1 1 0 0 0 1 0
    3200 0 0 0 0 0 0 0 1 0
    3600 0 0 1 0 0 0 0 0 0
    4000 0 0 0 0 0 0 0 0 0
    4400 0 0 0 0 0 0 0 1 0
    4800 0 0 0 0 0 0 0 0 0
    5200 0 0 0 0 0 0 0 0 0
    5600 0 0 0 0 0 0 0 0 0
    6000 0 0 0 0 0 0 0 0 0
    6400 0 0 0 0 0 0 0 0 0
    Narrow Avg 10
    Narrow Std. Dev. 10
    1200 0.0 0.5 0.0 0.0 0.0 0.0 0.0 0.0 0.0
    1600 0.0 0.5 4.6 0.0 5.0 0.0 0.0 0.0 0.0
    2000 0.0 0.0 0.0 0.0 4.1 0.0 0.0 0.0 0.0
    2400 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
    2800 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
    3200 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
    3600 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
    4400 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
    Wide Latest
    800 0.0 0.0 117.0 118.0 0.0 0.0 0.0 0.0 0.0
    1200 0.0 119.0 118.0 121.0 123.0 121.0 133.0 0.0 0.0
    1600 0.0 124.0 125.0 123.0 127.0 118.0 127.0 141.0 0.0
    2000 0.0 119.0 126.0 123.0 129.0 122.0 133.0 136.0 0.0
    2400 0.0 0.0 122.0 0.0 131.0 129.0 132.0 136.0 0.0
    2800 121.0 122.0 131.0 127.0 131.0 130.0 0.0 129.0 0.0
    3200 121.0 0.0 0.0 0.0 125.0 133.0 0.0 139.0 140.0
    3600 0.0 0.0 122.0 0.0 0.0 140.0 135.0 140.0 121.0
    4000 0.0 0.0 0.0 122.0 0.0 0.0 0.0 140.0 129.0
    4800 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 135.0
    Wide Avg
    800 0.0 0.0 117.0 123.8 0.0 0.0 0.0 0.0 0.0
    1200 0.0 120.0 121.0 115.1 120.6 127.5 133.0 0.0 0.0
    1600 0.0 120.4 120.6 118.7 121.3 120.0 130.0 141.0 0.0
    2000 0.0 121.8 126.0 121.8 126.8 130.4 133.2 138.0 0.0
    2400 0.0 0.0 121.2 0.0 131.0 131.3 132.7 135.5 0.0
    2800 121.0 122.0 123.8 127.4 129.5 130.0 0.0 135.3 0.0
    3200 121.0 0.0 0.0 0.0 129.3 133.0 0.0 139.0 140.0
    3600 0.0 0.0 122.0 0.0 0.0 137.5 135.0 140.0 121.0
    Wide # Samples
    800 0 0 1 4 0 0 0 0 0
    1200 0 5 2 8 5 2 1 0 0
    1600 0 8 15 18 10 4 2 1 0
    2000 0 4 1 6 49 15 16 7 0
    2400 0 0 5 0 1 8 7 2 0
    2800 2 1 5 5 2 3 0 4 0
    3200 2 0 0 0 3 1 0 2 1
    3600 0 0 1 0 0 2 1 1 1
    4000 0 0 0 1 0 0 0 2 1
    4400 0 0 0 0 0 0 0 2 0
    4800 0 0 0 0 0 0 0 0 1
    Wide Avg 10
    1600 0.0 120.4 121.3 122.1 121.3 120.0 130.0 141.0 0.0
    2000 0.0 121.8 126.0 121.8 127.8 130.4 132.9 138.0 0.0
    Wide Std. Dev. 10
    800 0.0 0.0 0.0 4.4 0.0 0.0 0.0 0.0 0.0
    1200 0.0 0.6 3.0 4.5 1.6 6.5 0.0 0.0 0.0
    1600 0.0 1.7 2.3 1.4 6.6 8.7 3.0 0.0 0.0
    2000 0.0 1.8 0.0 3.1 2.3 3.3 1.4 2.6 0.0
    2400 0.0 0.0 3.1 0.0 0.0 1.4 3.5 0.5 0.0
    2800 0.0 0.0 4.1 2.4 1.5 0.8 0.0 4.0 0.0
    3200 0.0 0.0 0.0 0.0 3.3 0.0 0.0 0.0 0.0
    3600 0.0 0.0 0.0 0.0 0.0 2.5 0.0 0.0 0.0
    Narrow Correction 10
    400 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
    800 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
    1200 1.000 0.941 1.000 1.000 1.000 1.000 1.039 1.000 1.000
    1600 1.000 0.935 0.931 1.000 0.961 1.000 1.000 1.000 1.000
    2000 1.000 1.000 1.000 1.000 0.969 1.031 1.039 1.000 1.000
    2400 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
    2800 1.000 1.000 0.945 0.992 1.000 1.000 1.000 1.055 1.000
    3200 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.086 1.000
    3600 1.000 1.000 0.953 1.000 1.000 1.000 1.000 1.000 1.000
    4000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
    4400 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.094 1.000
    4800 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
    5200 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
    5600 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
    6000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
    6400 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
    Wide Correction 10
    800 1.000 1.000 0.914 0.967 1.000 1.000 1.000 1.000 1.000
    1200 1.000 0.938 0.945 0.899 0.942 0.996 1.039 1.000 1.000
    1600 1.000 0.940 0.948 0.954 0.948 0.938 1.016 1.102 1.000
    2000 1.000 0.951 0.984 0.952 0.998 1.019 1.038 1.078 1.000
    2400 1.000 1.000 0.947 1.000 1.023 1.025 1.037 1.059 1.000
    2800 0.945 0.953 0.967 0.995 1.012 1.016 1.000 1.057 1.000
    3200 0.945 1.000 1.000 1.000 1.010 1.039 1.000 1.086 1.094
    3600 1.000 1.000 0.953 1.000 1.000 1.074 1.055 1.094 0.945
    4000 1.000 1.000 1.000 0.953 1.000 1.000 1.000 1.094 1.008
    4800 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.055
  7. 89Burben
    Jan 3, 2005
    98
    CT
    is it easier to email?? seems like alot of info.....i also have LOG,
    knock, INT, and O2
  8. Russell
    Jun 23, 2000
    7,921
    331
    In your case I'm gonna go with it being a timing problem more than a fuel problem.
    Since it it popping out the intake, that means the spark is likely too advanced at upper RPMs. That causes your fuel mixture to be burnt before it is suppost to be, which causes incomplete combustion, and once it gets bad enough, the combustion may occur in the intake, or head runners, which is the backfire you are hearing.
    Try backing the base timing back to the stock setting of 0 degrees BTDC, and see if the backfiring goes away, along with a drop in your BLMs to a more reasonable level. You will probally notice a loss of power across most of the powerband, but if the backfiring goes away, you know it is your timing that is at fault. This is also why tuning is so important, becuase by hammering out a new spark curve, you can take full advantage of the extra power you got from running more timing where the engine could use it, but also have proper timing in the top end so you don't get incomplete combustion etc.
    I realize that Brian knows waaayyy more about this stuff than I do, but just like I cannot know for sure, he can't either. Every engine runs a little different than another, and needs a chip that is built for that specific engine, by doing lots of datalogging, or dyno tuning.
    What he did by having you advance the base timing was kind of cheat, while it gave you more timing in the mid range, which your engine could likely benefit from, it also advanced the timing across the entire board by 8 degrees. The ECM has no idea where you set the base timing, it always assumes you are at 0 degrees, and adds timing as the prom dictates. So, while the stock chip has a pretty conservative spark curve, and can benefit a ton from 8 degrees in some areas of the powerband, those engines do run 40 degrees of total timing at WOT, and by adding an extra 8 degrees, you are putting it at almost 50 degrees, which is quite simply too much timing. Most carbed engines never go past 38 - 40 degrees total.
    All that said, with the ECM entering Power Enrich mode when you floor it can be pretty deciving too. It ignores the 02 sensor under PE, and simply pours the fuel on like crazy. You really can't have a totally accurate idea of what is happening in the top end with regards to what kind of A/F ratio you are running using the narrow band O2 sensor. This is where a wideband is almost a requirement to get your tune figured out properly. You can change the prom so that PE mode is disabled unless you put the TPS at 99%, and then still get feedback from the narrowband 02 sensor, but again, it will be a pretty foggy image of what is going on as compared to a wideband sensor.
  9. 89Burben
    Jan 3, 2005
    98
    CT
    well i guess that explains why it was backfiring worse at lower rpms with the timing set to 0*........
    what are my options here?
    call Brian and get my prom reflashed?
    i am somewhat new to tbi "tuning"
  10. Russell
    Jun 23, 2000
    7,921
    331
    Don't worry man, I'm not that far ahead of you, and a lot of it is still a bit like reading chineese to me too, lol
    However, it is still strange for the engine to backfire worse at lower rpms with the timing set to 0... Did it do that with the stock prom too?
    There is always the possiblity of a mechanical engine problem too, so don't rule that out unless you are 100% sure of the mechanical condition of the engine.
    Don't call Brian up just yet, try fiddling around to make sure everything is set up properly before getting a new prom flashed :)
    Oh, and can you email me all the logs? Are you running a wideband? What ECM?
    Email is Russell at ZieglerDigital.ca
  11. 89Burben
    Jan 3, 2005
    98
    CT
    i tried sending the folders to that email and it doesnt work. i used your hotmail email
  12. 89Burben
    Jan 3, 2005
    98
    CT
    u got any other emails? i got the hotmail account back too
  13. Russell
    Jun 23, 2000
    7,921
    331
    Yep, both emails worked, lol
    And I still stand by saying that I think it is probally more of a timing issue than anything. Give that a shot, and take another BLM log for me :)
  14. 89Burben
    Jan 3, 2005
    98
    CT
    what should i set the timing to?
    base?
  15. Russell
    Jun 23, 2000
    7,921
    331
    Try stock, at 0 first, if you've still got backfiring, try putting it a couple degrees ATDC instead of before. I don't quite know what Brian has done with your spark tables, but they may be too advanced...
    This is where the whole idea of tuning comes in -- Find out how your engine runs best, then once you have gotten it figured out, let Brian know, and he can flash a chip that'll be closer for your engine, but there is no way for him to know unless you experiment first to get an idea of what he needs to do :)
  16. 89Burben
    Jan 3, 2005
    98
    CT
    well it was at 11* BTDC, i changed it to 6* and it seems much better. I sent you an email
  17. Russell
    Jun 23, 2000
    7,921
    331
    Last email doesn't seem to have gone through -- Wanna try again?
  18. 89Burben
    Jan 3, 2005
    98
    CT
    i sent one to your hotmail account, ill try the other one too
