edelbrock performer RPM Intake
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jamie, Mar 28, 2001.
  1. Jamie
    Jamie Registered Member
    47
    Johnstown PA.
    Is any one useing this intake and how well does it perform.
  2. dyeager535
    26,978
    Need more info! High RPM use, use the RPM. Low end grunt (torque at low RPM's) get the plain performer. Bigger is not always better, just like everything else, it must be tailored to your anticipated usage
    Dorian
  3. K5_73
    K5_73 Registered Member
    Feb 5, 2001
    53
    Wichita, Kansas
    The Performer RPM is a good intake for all around use, and has a power range from 1500-6500 RPM. The Performer is also a good all around intake, but it's power range (idle to 5500) is a little better for low end, as dyeager535 said. It just depends on what you want out of your motor.
    Stupid hurts
  4. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    im runnin an RPM it was more suited to what i built.idle to 5500 is useless if your motor IDLES at 1200.idle is a BIG variable,for me i needed to start pulling higher up than 6-800 rpm cause i dont idle that low.i also have a 2500 stall and 4:88 gears so it all works together.
    PURE INSANITY
    86 blazer silverado 400 horse 350 w/vortec heads 38 x15.5 swampers (40 hawgs next)10 bolts(blah)w/4:88s coming soon,14 bolt.
  5. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I don't ever go above 5500 rpm so when I put an edelbrock intake on, I'll go for the regular performer. I had one on a dually with a 383 stroker and hoooweee!!! You weren't stoppin that truck!!!
    <A target="_blank" HREF=http://muddin4fun.coloradok5.com>http://muddin4fun.coloradok5.com</A>
  6. K5_73
    Feb 5, 2001
    53
    Wichita, Kansas
    Sweet! That's what's going in the Blazer, as soon as I get the heads done! 383 should be pretty peppy w/ 4.10 gears behind it.
    Stupid hurts
  7. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    Well I have one on my Blazer and love it. The RPM in dyno test after dyno test makes more hp and tq. the whole rpm range. The old myth that the performer is better in the low rpm is false, old myth. But the RPM is a square bore only.
    Displacement, cubes, and did you say you drive a riceburner???
  8. dyeager535
    26,978
    No, thats a fact. You can not flow better at low RPM AND High RPM. Dyno tests do NOT and cannot accurately show low RPM hp/tq. They typically start at 2000RPM. I don't know about anyone else here, but if my motor makes 5 ft lbs of torque off idle, that truck won't start moving, even if it makes 4 billion foot pounds at 4000RPM. There is no argument it makes more horsepower and torque. It's WHERE it makes it. just like a cam, bigger is not better in all cases.
    Dorian
  9. Jamie
    47
    Johnstown PA.
    The reason I asked this question is because I need an Intake with a heat crossover. So I choose the edelbrock 7116 for the vortec heads I have and will be installing soon. I have a performer 2116 now but for the past to winters here in PA the lack of a heat crossover makes getting around a problem cause the cold fuel mixture hits that cold Intake and turns the fuel back into a liquid. The performer RPM 7116 has an external heat crossover that I plan on hooking up to my headers. I had contacted Edelbrock and said that everything should work fine together. The bottom end is still a stock 400 and my cam is and edelbrock 2103 (400) cam and the vortec heads. The only bad thing is that I have to replace my Q-Jet with a performer 750 carb. If anyone is running a performer cam and performer rpm intake and performer carb I would appriciate any feedback thanx.
  10. Nrose07
    Mar 29, 2000
    267
    Salem ,Or
    Well that is also a plus about the RPM, it will solve your problem. This is the setup that I use, 350, TBI, adapter (tbi-squarebore), vortec heads, etc. I run coolant out of the front of the intake, through the crossover, and onto my heater core. The reason that I belive this a better setup then exhaust is that your intake manifold temp. will be regulated to your thermostat. When running exhaust through your crossover the temp. is MUCH higher than needed, is unregulated, and when working the motor (say going up a long hill) your exhaust temp. will rise heating your intake charge creating a lean condition, reducing power and possible pre-detonation.
    The con of running coolant is you have to wait a few min for coolant temp. to rise sufficently. Also you can get away with adapter so you not spending the money on a new carb.
