edelbrock tuning
Discussion in 'The Garage' started by bigbadchev84, Oct 12, 2004.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    i have a 750 edelbrock on my 350, it is completely stock with an aluminum performer intake and 6inch k&n filter i was told that i could de-jet it to make it run better, right now it is running too rich and it burns my eyes when i try to drive it, does anyone know what i could do to fix the problem? jet sizes, metering rods? etc. i would like to use this carb i got it in trade and it was brand new, i cant afford to get a new one right now, i just want this one to run good for now until i can afford a quadrajet
  2. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    I'd go to www.edelbrock.com and look up the carb you have--they have all the manuals and jet charts,etc.there,along with tons of info on troubleshooting and exploded diagrams. A 750 is a pretty big carb for a 350,unless its a built 350 with a hotter cam than stock. /forums/images/graemlins/crazy.gif
  3. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    750 is way too big a carb for a 350 unless you are revving the wee out of it (7000+).
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
  5. 76SILVERADO
    76SILVERADO Registered Member
    Mar 1, 2003
    52
    AZ
    most stock quadrajets are 750cfm.....
  6. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    Bull [censored]! According the the Haynes Rochester Manual, a 450CUI engine that runs at 6,500 RPM would use 700 CFM!
    This is just a case of an over-carburetted engine.
    Here are 350 specks:
    4000RPM - 325CFM
    4500RPM - 365CFM
    5000RPM - 405CFM
    5500RPM - 445CFM
    6000RPM - 490CFM
    6500RPM - 525CFM
    I have a good working stock 1985 Quadra Jet off of a 1985 K5 with a 305 that I would sell you for $50.00 too your door. /forums/images/graemlins/deal.gif
    It would *run* the 350 or you could jet it and tune it and it will run the 350!! /forums/images/graemlins/thumb.gif
  7. 76SILVERADO
    Mar 1, 2003
    52
    AZ
  8. rhuarc31
    rhuarc31 Registered Member
    Oct 21, 2003
    94
    Decatur, IL
    Well, your both right. A quadrajet is rated at 750 cfm, some at 800, but ... GM in effect made a variable cfm carb by putting limiting stops on the secondary air valve to limit flow, as well as a spring on the air valve that makes it act more like a vacuum secondary carb. In addition the secondaries on the stock q jet don't start to open till around 70% throttle, which means that most of the time you only run off the primaries.
    Heh almost forgot. But in reply to the original post. Pick up a tuning kit for the edelbrock. It will come with several jets, metering rods, and a few power valve springs. Most problems can be solved by changing the rods, and sometimes springs, which is nice because you don't have to disassemble the carburetor to do it. I bought one for a carter one time (same design carburetor) and it came with a lot more jets and rods, but not the springs (which are available seperately). So take your pick.
  9. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    Hmm...
    Guess I was partially wrong, very wrong about the CFM that the carb is rated for. But that truck is definitly over carburetted.
    Are you interested in the carb, or are you hoping I'd be stubborn and insist I'm right? /forums/images/graemlins/deal.gif /forums/images/graemlins/rolleyes.gif
